Источники питания Keen Side
Datasheet LTC4078EDD - Linear Technology Даташит BATT зарядное устройство, LI ON, сдвоенный, 10DFN — Даташит
Linear Technology LTC4078EDD
Наименование модели: LTC4078EDD
28 предложений от 20 поставщиков
Linear Battery Charger Li-Ion/Li-Pol 950mA 4.2V 10-Pin DFN EP T/R / IC USB POWER MANAGER 10-DFN
LTC4078EDD#PBF
153 ₽
ЭИК
LTC4078EDD#PBF
от 624 ₽
LTC4078EDD-2#PBF
LTC4078EDD
Производитель: Linear Technology
Описание: BATT зарядное устройство, LI ON, сдвоенный, 10DFN
data sheetСкачать Data Sheet
LTC4078/LTC4078X Dual Input Li-Ion Battery Charger with Overvoltage Protection FEATURES
n n n n n n n n n n n n n n n
DESCRIPTION
The LTC®4078/LTC4078X are standalone linear chargers that are capable of charging a single-cell Li-Ion/Polymer battery from both wall adapter and USB inputs.
The chargers can detect power at the inputs and automatically select the appropriate power source for charging. No external sense resistor or blocking diode is required for charging due to the internal MOSFET architecture. The LTC4078/LTC4078X feature a maximum 22V rating for both wall adapter and USB inputs, although charging stops if the selected power source exceeds the overvoltage limit. Internal thermal feedback regulates the battery charge current to maintain a constant die temperature during high power operation or high ambient temperature conditions. The float voltage is fixed at 4.2V and the charge current is programmed with an external resistor. The LTC4078/LTC4078X terminate the charge cycle
  • Battery Type: Li-Ion
  • Входное напряжение: 5.5 В
  • Battery Charge Voltage: 4.2 В
  • Charge Current Max: 950 мА
  • Battery IC Case Style: DFN
  • Количество выводов: 10
  • Number of Series Cells: 1
  • Рабочий диапазон температрур: -40°C ... +85°C
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: DFN
  • Семейство: 4078
  • Battery Management Function: Charger
  • Входное напряжение максимальное: 5.5 В
  • Выходное напряжение максимальное: 4.2 В
  • Способ монтажа: SMD
  • Диапазон напряжения питания: 4.3 В ... 5.5 В
На английском языке: Datasheet LTC4078EDD - Linear Technology BATT CHARGER, LI ON, DUAL, 10DFN
