Datasheet LTC4081EDD - Linear Technology Даташит ИС, BATT зарядное устройство, маломощный, 10DFN — Даташит
Наименование модели: LTC4081EDD
28 предложений от 18 поставщиков Linear Battery Charger Li-Ion/Li-Pol 500mA 4.2V 10-Pin DFN EP Tube / IC USB POWER MANAGER 10-DFN | |||
LTC4081EDD#PBF Analog Devices | 82 ₽ | ||
LTC4081EDD#TRPBF Linear Technology | 182 ₽ | ||
LTC4081EDD#TRPBF Analog Devices | 251 ₽ | ||
LTC4081EDD#TRPBF Linear Technology | по запросу |
Производитель: Linear Technology
Описание: ИС, BATT зарядное устройство, маломощный, 10DFN
FEATURES
Battery Charger: Constant-Current/Constant-Voltage Operation with Thermal Feedback to Maximize Charge Rate Without Risk of Overheating Internal 4.5 Hour Safety Timer for Termination Charge Current Programmable Up to 500mA with 5% Accuracy NTC Thermistor Input for Temperature Qualified Charging C/10 Charge Current Detection Output 5A Supply Current in Shutdown Mode Switching Regulator: High Efficiency Synchronous Buck Converter 300mA Output Current (Constant-Frequency Mode) 2.7V to 4.5V Input Range (Powered from BAT Pin) 0.8V to V BAT Output Range MODE Pin Selects Fixed (2.25MHz) Constant-Frequency PWM Mode or Low ICC (23A) Burst Mode® Operation 2A BAT Current in Shutdown Mode 10-lead, low profile (0.75 mm) 3mm Ч 3mm DFN package
LTC4081 500mA Li-Ion Charger with NTC Input and 300mA Synchronous Buck DESCRIPTIO
The LTC4081 is a complete constant-current/constantvoltage linear battery charger for a single-cell 4.2V lithium-ion/polymer battery with an integrated 300mA
- Battery Type: Li-Ion / Li-Polymer
- Входное напряжение: 5.5 В
- Battery Charge Voltage: 3.8 В
- Charge Current Max: 525 мА
- Battery IC Case Style: DFN
- Количество выводов: 10
- Number of Series Cells: 1
- Рабочий диапазон температрур: 0°C ...
+70°C
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: DFN
- Семейство: 4081
- Battery Management Function: Charger
- Входное напряжение максимальное: 4.5 В
- Выходное напряжение максимальное: 4.24 В
- Способ монтажа: SMD
- Диапазон напряжения питания: 3.75 В ... 5.5 В
