Линейка продуктов KEEN SIDE
Datasheet LTC4090EDJC - Linear Technology Даташит ИС, USB мощность MANAGER, 22DFN — Даташит
Linear Technology LTC4090EDJC
Наименование модели: LTC4090EDJC
41 предложений от 24 поставщиков
Микросхема Чип управления батареи, USB Power Manager 4.35V to 5.5V Automotive 22Pin DFN EP Tube
LTC4090EDJC#PBF
246 ₽
LTC4090EDJC#TRPBF
310 ₽
LTC4090EDJC#PBF
LTC4090EDJC-5#PBF
Производитель: Linear Technology
Описание: ИС, USB мощность MANAGER, 22DFN
data sheetСкачать Data Sheet
FEATURES
LTC4090/LTC4090-5 USB Power Manager with 2A High Voltage Bat-Track Buck Regulator DESCRIPTION
The LTC®4090/LTC4090-5 are USB power managers plus high voltage Li-Ion/Polymer battery chargers.
The devices control the total current used by the USB peripheral for operation and battery charging. Battery charge current is automatically reduced such that the sum of the load current and the charge current does not exceed the programmed input current limit. The LTC4090/LTC4090-5 also accommodate high voltage power supplies, such as 12V AC/DC wall adapters, FireWire, or automotive power. The LTC4090 provides a Bat-Track adaptive output that tracks the battery voltage for high efficiency charging from the high voltage input. The LTC4090-5 provides a fixed 5V output from the high voltage input to charge single cell Li-Ion bateries. The charge current is programmable and an end-of-charge status output (CHRG) indicates full charge. Also featured are programmable total charge time, an NT
  • Battery Type: Li-Ion
  • Входное напряжение: 5.5 В
  • Battery Charge Voltage: 4.2 В
  • Charge Current Max: 1.5 А
  • Battery IC Case Style: DFN
  • Количество выводов: 22
  • Number of Series Cells: 1
  • Рабочий диапазон температрур: -40°C ... +85°C
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: DFN
  • Семейство: 4090
  • Battery Management Function: Charger, Protector
  • Входное напряжение максимальное: 5.5 В
  • Выходное напряжение максимальное: 4.2 В
  • Способ монтажа: SMD
  • Диапазон напряжения питания: 4.35 В ... 5.5 В
На английском языке: Datasheet LTC4090EDJC - Linear Technology IC, USB POWER MANAGER, 22DFN
