Datasheet LTC4096EDD - Linear Technology Даташит BATT зарядное устройство, LI ON, сдвоенный, 10DFN — Даташит
Linear Technology LTC4096EDD
Наименование модели: LTC4096EDD
26 предложений от 17 поставщиков
Микросхема Чип управления батареи, LINEAR TECHNOLOGY LTC4096EDD#PBF Battery Charger for 1 Cell of Li-Ion, Li-Pol battery, 5.5V input, 4.242V/1.2A charge, DFN-10...
LTC4096EDD#PBF
356 ₽
ЭИК
LTC4096EDD#PBF
от 474 ₽
Элитан
LTC4096EDD
740 ₽
ЗУМ-СМД
LTC4096EDD
Производитель: Linear Technology
Описание: BATT зарядное устройство, LI ON, сдвоенный, 10DFN
data sheetСкачать Data Sheet
LTC4096/LTC4096X Dual Input Standalone Li-Ion Battery Chargers FEATURES
DESCRIPTION
The LTC®4096/LTC4096X are standalone linear chargers that are capable of charging a single-cell Li-Ion or Li-Polymer battery from both wall adapter and USB inputs.
The chargers can detect power at the inputs and automatically select the appropriate power source for charging. No external sense resistor or blocking diode is required for charging due to the internal MOSFET architecture. Internal thermal feedback regulates the battery charge current to maintain a constant die temperature during high power operation or high ambient temperature conditions. The float voltage is fixed at 4.2V and the charge current is programmed with an external resistor. The LTC4096 terminates the charge cycle when the charge current drops below the user programmed termination threshold after the final float voltage is reached. The LTC4096 can be put into shutdown mode reducing the DCIN supply current to 20µA, the
  • Battery Type: Li-Ion
  • Входное напряжение: 5.5 В
  • Battery Charge Voltage: 4.2 В
  • Charge Current Max: 1.2 А
  • Battery IC Case Style: DFN
  • Количество выводов: 10
  • Number of Series Cells: 1
  • Рабочий диапазон температрур: -40°C ... +85°C
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: DFN
  • Семейство: 4096
  • Battery Management Function: Charger
  • Входное напряжение максимальное: 5.5 В
  • Выходное напряжение максимальное: 4.2 В
  • Способ монтажа: SMD
  • Диапазон напряжения питания: 4.25 В ... 5.5 В
На английском языке: Datasheet LTC4096EDD - Linear Technology BATT CHARGER, LI ON, DUAL, 10DFN
