Datasheet LTC4100EG - Linear Technology Даташит Зарядное устройство батареи аккумуляторов, SMD, SSOP24, 4100 — Даташит
Наименование модели: LTC4100EG
Купить LTC4100EG на РадиоЛоцман.Цены — от 379 до 2 604 ₽ 36 предложений от 22 поставщиков LINEAR TECHNOLOGY LTC4100EG#PBF Battery Charger for 1 Cell of Li-Ion battery, 28V input, 12V / 4A charge, SSOP-24 | |||
LTC4100EG Analog Devices | 379 ₽ | ||
LTC4100EG#TR Linear Technology | 453 ₽ | ||
LTC4100EG#PBF Linear Technology | 664 ₽ | ||
LTC4100EG1 | по запросу |
Производитель: Linear Technology
Описание: Зарядное устройство батареи аккумуляторов, SMD, SSOP24, 4100
LTC4100 Smart Battery Charger Controller DESCRIPTIO
The LTC®4100 Smart Battery Charger is a single chip charging solution that dramatically simplifies construction of an SBS compliant system.
The LTC4100 implements a Level 2 charger function whereby the charger can be programmed by the battery or by the host. A SafetySignal on the battery being charged is monitored for temperature, connectivity and battery type information. The SMBus interface remains alive when the AC power adapter is removed and responds to all SMBus activity directed to it, including SafetySignal status (via the ChargerStatus command). The charger also provides an interrupt to the host whenever a status change is detected (e.g., battery removal, AC adapter connection). Charging current and voltage are restricted to chemistryspecific limits for improved system safety and reliability. Limits are programmable by two external resistors. Additionally, the maximum average current from the AC adapter is programmable to avo
- Battery Charge Voltage: 12 В
- Battery IC Case Style: SSOP
- Battery Management Function: Charger
- Battery Type: Li-Ion
- Charge Current Max: 4 А
- Входное напряжение максимальное: 28 В
- Входное напряжение: 28 В
- Выходное напряжение максимальное: 26 В
- Выходное напряжение: 32 В
- Выходной ток максимальный: 3.9 А
- Диапазон напряжения питания: 6 В ... 28 В
- Количество выводов: 24
- Напряжения питания Vcc: 7 В
- Рабочий диапазон температрур: -40°C ... +85°C
- Семейство: 4100
- Способ монтажа: SMD
- Тип корпуса: SSOP
- Упаковка: Peel Pack
- RoHS: да
- SVHC: No SVHC (18-Jun-2012)
