Datasheet LTM8061EV-4.1 - Linear Technology Даташит ИС, BATT CHRG, Li-Ion, Li-Polymer, 2 А, LGA77 — Даташит
Linear Technology LTM8061EV-4.1
Наименование модели: LTM8061EV-4.1
35 предложений от 17 поставщиков
Linear Battery Charger Lead-Acid/Li-FePO4/Li-Ion/Li-Pol 2000mA 4.1V Automotive 77-Pin LGA Tray / IC BATTERY CHARGER 4.1V 77-LGA
LTM8061EV-4.1#PBF
от 379 ₽
LTM8061EV-4.1#PBF
696 ₽
Эиком
LTM8061EV-4.1#PBF
от 2 528 ₽
LTM8061EV-4.1#PBF
Производитель: Linear Technology
Описание: ИС, BATT CHRG, Li-Ion, Li-Polymer, 2 А, LGA77
data sheetСкачать Data Sheet
LTM8061 32V, 2A µModule Li-Ion/ Polymer Battery Charger FEATURES
n n
DESCRIPTION
The LTM®8061 is a high efficiency 32V, 2A Module® standalone Li-Ion battery charger.
It is optimized for one and two-cell packs, with fixed float voltage options: 4.1V, 4.2V, 8.2V and 8.4V. The LTM8061 provides a constantcurrent/constant-voltage charge characteristic, with maximum charge current up to 2A. A precondition feature trickle charges a depleted battery, and bad battery detection provides a signal and suspends charging if a battery does not respond to preconditioning. The LTM8061 can be configured to terminate charging when charge current falls to one-tenth the programmed maximum current or to use an internal timer if a timebased termination scheme is desired. Once charging is terminated, the LTM8061 enters a low current standby mode. An auto-restart feature starts a new charge cycle if the battery voltage drops 2.5% from the float voltage, or if a new battery is inserted into a charging system.
  • Battery Charge Voltage: 4.1 В
  • Battery IC Case Style: LGA
  • Battery Type: Li-Ion / Li-Polymer
  • Charge Current Max: 2 А
  • Number of Series Cells: 1
  • Входное напряжение: 32 В
  • Количество выводов: 77
  • RoHS: да
LTM8061EV4.1, LTM8061EV 4.1
На английском языке: Datasheet LTM8061EV-4.1 - Linear Technology IC, BATT CHRG, Li-Ion, Li-Polymer, 2 A, LGA77
