Клеммные колодки Keen Side
Datasheet LTM8062EV - Linear Technology Даташит ИС, BATT CHRG, Li-Ion, Li-Polymer, 2 А, LGA77 — Даташит
Linear Technology LTM8062EV
Наименование модели: LTM8062EV
32 предложений от 16 поставщиков
Микросхема Чип управления батареи, Battery Charger 2100mA 3.3V to 14.4V Automotive 77Pin LGA Tray
LTM8062EV#PBF
от 425 ₽
T-electron
LTM8062EV#PBF
1 075 ₽
LTM8062EV#PBF
1 188 ₽
Элитан
LTM8062EV
2 844 ₽
Производитель: Linear Technology
Описание: ИС, BATT CHRG, Li-Ion, Li-Polymer, 2 А, LGA77
data sheetСкачать Data Sheet
LTM8062/LTM8062A 32VIN, 2A µModule Power Tracking Battery Chargers FEATURES
n n
DESCRIPTION
The LTM®8062/LTM8062A are complete 32VIN, 2A µModule® power tracking battery chargers.
The LTM8062/ LTM8062A provide a constant-current/constant-voltage charge characteristic, a 2A maximum charge current, and employ a 3.3V float voltage feedback reference, so any desired battery float voltage up to 14.4V for the LTM8062 and up to 18.8V for the LTM8062A can be programmed with a resistor divider. The LTM8062/LTM8062A employ an input voltage regulation loop, which reduces charge current if the input voltage falls below a programmed level, set with a resistor divider. When the LTM8062/LTM8062A are powered by a solar panel, this input regulation loop is used to maintain the panel at peak output power. The LTM8062/LTM8062A also feature preconditioning trickle charge, bad battery detection, a choice of termination schemes and automatic restart. The LTM8062/LTM8062A are packaged in a thermally enhanced
  • Battery Charge Voltage: 14.4 В
  • Battery IC Case Style: LGA
  • Battery Type: Li-Ion / Li-Polymer
  • Charge Current Max: 2 А
  • Number of Series Cells: 1
  • Входное напряжение: 32 В
  • Количество выводов: 77
  • RoHS: да
На английском языке: Datasheet LTM8062EV - Linear Technology IC, BATT CHRG, Li-Ion, Li-Polymer, 2 A, LGA77
