Datasheet LTM8062IV - Linear Technology Даташит ИС, BATT CHRG, Li-Ion, Li-Polymer, 2 А, LGA77 — Даташит
Наименование модели: LTM8062IV
![]() 22 предложений от 13 поставщиков Switching Battery Charger Lead-Acid/Li-FePO4/Li-Ion/Li-Pol 2100mA 3.3V to 14.4V Automotive 77-Pin LGA Tray / IC BATTERY CHARGER TRACK 77-LGA | |||
LTM8062IV#PBF | 1 749 ₽ | ||
LTM8062IV Analog Devices | 3 415 ₽ | ||
LTM8062IV#PBF Linear Technology | по запросу | ||
LTM8062IV#PBF Analog Devices | по запросу |
Производитель: Linear Technology
Описание: ИС, BATT CHRG, Li-Ion, Li-Polymer, 2 А, LGA77
LTM8062/LTM8062A 32VIN, 2A µModule Power Tracking Battery Chargers FEATURES
n n
DESCRIPTION
The LTM®8062/LTM8062A are complete 32VIN, 2A µModule® power tracking battery chargers.
The LTM8062/ LTM8062A provide a constant-current/constant-voltage charge characteristic, a 2A maximum charge current, and employ a 3.3V float voltage feedback reference, so any desired battery float voltage up to 14.4V for the LTM8062 and up to 18.8V for the LTM8062A can be programmed with a resistor divider. The LTM8062/LTM8062A employ an input voltage regulation loop, which reduces charge current if the input voltage falls below a programmed level, set with a resistor divider. When the LTM8062/LTM8062A are powered by a solar panel, this input regulation loop is used to maintain the panel at peak output power. The LTM8062/LTM8062A also feature preconditioning trickle charge, bad battery detection, a choice of termination schemes and automatic restart. The LTM8062/LTM8062A are packaged in a thermally enhanced
- Battery Charge Voltage: 14.4 В
- Battery IC Case Style: LGA
- Battery Type: Li-Ion / Li-Polymer
- Charge Current Max: 2 А
- Number of Series Cells: 1
- Входное напряжение: 32 В
- Количество выводов: 77
- RoHS: да
