Datasheet MAX1551EZK+T - Maxim Даташит ИС, зарядное устройство батареи аккумуляторов LI-ION 340 мА SOT23-5 — Даташит
Наименование модели: MAX1551EZK+T
![]() 43 предложений от 17 поставщиков Микросхема Чип управления батареи, MAXIM INTEGRATED PRODUCTS MAX1551EZK+T Battery Charger for 1 Cell of Li-Ion, Li-Pol battery, 7V input, 4.2V /... | |||
MAX1551EZK+T Maxim | от 34 ₽ | ||
MAX1551EZK+T Maxim | 62 ₽ | ||
MAX1551EZK+T Maxim | 185 ₽ | ||
MAX1551EZK+T | по запросу |
Производитель: Maxim
Описание: ИС, зарядное устройство батареи аккумуляторов LI-ION 340 мА SOT23-5
19-2902; Rev 0; 7/03
SOT23 Dual-Input USB/AC Adapter 1-Cell Li+ Battery Chargers
General Description
The MAX1551/MAX1555 charge a single-cell lithium-ion (Li+) battery from both USB* and AC adapter sources.
They operate with no external FETs or diodes, and accept operating input voltages up to 7V. On-chip thermal limiting simplifies PC board layout and allows optimum charging rate without the thermal limits imposed by worst-case battery and input voltage. When the MAX1551/MAX1555 thermal limits are reached, the chargers do not shut down, but progressively reduce charging current. The MAX1551 includes a POK output to indicate when input power is present. If either charging source is active, POK goes low. The MAX1555 instead features a CHG output to indicate charging status. With USB connected, but without DC power, charge current is set to 100mA (max). This allows charging from both powered and unpowered USB hubs with no port communication required. When DC power is connected, charging
- Battery Charge Voltage: 4.2 В
- Battery IC Case Style: SOT-23
- Battery Type: Li-Ion
- Charge Current Max: 340 мА
- Number of Series Cells: 1
- Входное напряжение: 7 В
- Количество выводов: 5
- RoHS: да
