Datasheet MAX1758EAI+ - Maxim Даташит Зарядное устройство батареи аккумуляторов, LI-ION, 28 В, 20SSOP — Даташит
Наименование модели: MAX1758EAI+
Производитель: Maxim
Описание: Зарядное устройство батареи аккумуляторов, LI-ION, 28 В, 20SSOP
19-1752; Rev 1; 1/01
Stand-Alone, Switch-Mode Li+ Battery Charger with Internal 28V Switch
General Description
The MAX1758 is a switch-mode lithium-ion (Li+) battery charger that charges one-to-four cells.
It provides a regulated charging current accurate to ±10% and a regulated voltage with only a ±0.8% total voltage error at the battery terminals. The internal high-side switch delivers a programmable current of up to 1.5A to charge the battery. The built-in safety timer automatically terminates charging once the adjustable time limit has been reached. The MAX1758 regulates the voltage set point and charging current using two loops that work together to transition smoothly between voltage and current regulation. An additional control loop monitors the total current drawn from the input source (charging + system), and automatically reduces battery-charging current, preventing overload of the input supply and allowing the use of a low-cost wall adapter. The per-cell battery regulation
- Battery Type: Li-Ion / Li-Polymer
- Входное напряжение: 28 В
- Battery Charge Voltage: 4.2 В
- Charge Current Max: 1.5 А
- Battery IC Case Style: SSOP
- Количество выводов: 20
- Number of Series Cells: 4
- Рабочий диапазон температрур: -40°C ... +85°C
- SVHC: No SVHC (18-Jun-2010)
- Тип корпуса: SSOP
- Семейство: 1758
- Battery Management Function: Charger
- Входное напряжение максимальное: 28 В
- Выходное напряжение максимальное: 5.7 В
- Способ монтажа: SMD
- Диапазон напряжения питания: 6 В ... 28 В
Дополнительные аксессуары:
- Electrolube - HTS35SL
- Fischer Elektronik - ICK SMD A 5 SA
- Roth Elektronik - RE931-05
- STANNOL - 574601
