Datasheet MAX1874ETE+ - Maxim Даташит ИС, BATT зарядное устройство, LI-ION, 16TQFN — Даташит
Maxim MAX1874ETE+
Наименование модели: MAX1874ETE+
36 предложений от 21 поставщиков
Микросхема Чип управления батареи, MAXIM INTEGRATED PRODUCTS MAX1874ETE+ Battery Charger for 1 Cell of Li-Ion battery, 18V input, 6.5V / 1A...
MAX1874ETE+
Maxim
137 ₽
MAX1874ETE+
Maxim
847 ₽
LifeElectronics
MAX1874ETE-T
Maxim
MAX1874ETE+T
Maxim
Производитель: Maxim
Описание: ИС, BATT зарядное устройство, LI-ION, 16TQFN
data sheetСкачать Data Sheet
19-2912; Rev 1; 2/07
Dual-Input, USB/AC Adapter, 1-Cell Li+ Charger with OVP and Thermal Regulation
General Description
The MAX1874 charges a single-cell Li+ battery from both USB and AC adapter sources.
It also includes battery-to-input power switchover, so the system can be powered directly from the power source rather than from the battery. In its simplest application, the MAX1874 needs no external MOSFET or diodes, and accepts input voltages up to 6.5V; however, DC input overvoltage protection up to 18V can be added with a single SOT PFET. On-chip thermal limiting simplifies printed circuit board (PCB) layout and allows optimum charging rate without the thermal limits imposed by worst-case battery and input voltage. When the MAX1874 thermal limit is reached, the charger does not shut down but simply reduces charging current. Ambient or battery temperature can be monitored with an external thermistor. When the temperature is out of range, charging pauses. Other features include a C
  • Battery Type: Li-Ion / Li-Polymer
  • Входное напряжение: 18 В
  • Battery Charge Voltage: 4.2 В
  • Charge Current Max: 1 А
  • Battery IC Case Style: TQFN
  • Количество выводов: 16
  • Number of Series Cells: 1
  • Рабочий диапазон температрур: -40°C ... +85°C
  • SVHC: No SVHC (18-Jun-2010)
  • Тип корпуса: TQFN
  • Семейство: 1874
  • Battery Management Function: Charger, Protector
  • Входное напряжение максимальное: 18 В
  • Способ монтажа: SMD
  • Диапазон напряжения питания: 4.35 В ... 6 В
На английском языке: Datasheet MAX1874ETE+ - Maxim IC, BATT CHARGER, LI-ION, 16TQFN
