Datasheet MAX1908ETI+ - Maxim Даташит ИС, BATT зарядное устройство, LI-ION, 28TQFN — Даташит
Наименование модели: MAX1908ETI+
Купить MAX1908ETI+ на РадиоЛоцман.Цены — от 119 до 1 674 ₽46 предложений от 23 поставщиков Микросхема Чип управления батареи, MAXIM INTEGRATED PRODUCTS MAX1908ETI+ Battery Charger for 4 Cells of Li-Ion battery, 28V input, 4.2V / 5A... | |||
| MAX1908ETI+ Analog Devices | 324 ₽ | ||
| MAX1908ETI Maxim | от 994 ₽ | ||
| MAX1908ETI-T Maxim | по запросу | ||
| MAX1908ETI+ Maxim | по запросу | ||
Производитель: Maxim
Описание: ИС, BATT зарядное устройство, LI-ION, 28TQFN
19-2764; Rev 4; 7/05
KIT ATION EVALU BLE AVAILA
Low-Cost Multichemistry Battery Chargers
General Description
The MAX1908/MAX8724/MAX8765 highly integrated, multichemistry battery-charger control ICs simplify the construction of accurate and efficient chargers.
These devices use analog inputs to control charge current and voltage, and can be programmed by the host or hardwired. The MAX1908/MAX8724/MAX8765 achieve high efficiency using a buck topology with synchronous rectification. The MAX1908/MAX8724/MAX8765 feature input current limiting. This feature reduces battery charge current when the input current limit is reached to avoid overloading the AC adapter when supplying the load and the battery charger simultaneously. The MAX1908/MAX8724/ MAX8765 provide outputs to monitor current drawn from the AC adapter (DC input source), battery-charging current, and the presence of an AC adapter. The MAX1908's conditioning charge feature provides 300mA to safely charge deeply discharged lithiu
- Battery Type: Universal
- Входное напряжение: 28 В
- Battery Charge Voltage: 19 В
- Charge Current Max: 5 А
- Battery IC Case Style: TQFN
- Количество выводов: 28
- Number of Series Cells: 4
- Рабочий диапазон температрур: -40°C ... +85°C
- SVHC: No SVHC (18-Jun-2010)
- Тип корпуса: TQFN
- Семейство: 1908
- Battery Management Function: Charger
- Входное напряжение максимальное: 28 В
- Способ монтажа: SMD
- Диапазон напряжения питания: 8 В ... 28 В
