Datasheet MAX8600ETD+T - Maxim Даташит BATT зарядное устройство, LI-ION, одиночный, 14TDFN — Даташит
Наименование модели: MAX8600ETD+T
![]() 24 предложений от 11 поставщиков Микросхема Чип управления батареи, Power Supply Support Circuit, Adjustable, 1Channel, BICMOS, 3 X 3MM, 0.8MM HEIGHT, ROHS COMPLIANT, MO-229, TDFN-14 | |||
MAX8600ETD+T Maxim | 64 ₽ | ||
MAX8600ETD+T Maxim | 163 ₽ | ||
MAX8600ETD+T Analog Devices | от 532 ₽ | ||
MAX8600ETD+T Analog Devices | по запросу |
Производитель: Maxim
Описание: BATT зарядное устройство, LI-ION, одиночный, 14TDFN
19-3565; Rev 2; 7/08
KIT ATION EVALU ILABLE AVA
Single-/Dual-Input 1-Cell Li+ Chargers with OVP Protection and Programmable Charge Timer
General Description
The MAX8600/MAX8601 single-/dual-input linear battery chargers safely charge single-cell Li+ batteries.
The charging rate is optimized to accommodate the thermal characteristics of a given application. There is no need to reduce the maximum charge current or worst-case charger power dissipation. Charging is optimized for Li+ cells using a control algorithm that includes low-battery precharging, voltage and currentlimited fast-charging, and top-off charging, while continuously monitoring the battery for overvoltage, over/undertemperature, and charging time. The charger timeout protection is programmable. The charger status is indicated by three open-drain outputs. The MAX8601 automatically selects between either a USB or AC adapter input source. The AC adapter charge current is programmable, while USB charge current is set not to
- Battery Type: Li-Ion / Li-Polymer
- Входное напряжение: 14 В
- Battery Charge Voltage: 4.2 В
- Charge Current Max: 1 А
- Battery IC Case Style: TDFN
- Количество выводов: 14
- Number of Series Cells: 1
- Рабочий диапазон температрур: -40°C ... +85°C
- SVHC: No SVHC (18-Jun-2010)
- Тип корпуса: TDFN
- Семейство: 8600
- Battery Management Function: Charger, Protector
- Входное напряжение максимальное: 14 В
- Способ монтажа: SMD
- Диапазон напряжения питания: 4.15 В ... 7 В
