Datasheet MAX8601ETD+T - Maxim Даташит ИС, зарядное устройство батареи аккумуляторов, LI-ION, 1 А, TDFN-14 — Даташит
Наименование модели: MAX8601ETD+T
Купить MAX8601ETD+T на РадиоЛоцман.Цены — от 66 до 796 ₽32 предложений от 16 поставщиков Микросхема Чип управления батареи, Battery Protection Li-Ion/Li-Pol 1000mA 4.2V 14Pin TDFN EP T/R | |||
| MAX8601ETD+T Maxim | 109 ₽ | ||
| MAX8601ETD+T Maxim | 390 ₽ | ||
| MAX8601ETD-T Maxim | по запросу | ||
| MAX8601ETD+T Maxim | по запросу | ||
Производитель: Maxim
Описание: ИС, зарядное устройство батареи аккумуляторов, LI-ION, 1 А, TDFN-14
19-3565; Rev 2; 7/08
KIT ATION EVALU ILABLE AVA
Single-/Dual-Input 1-Cell Li+ Chargers with OVP Protection and Programmable Charge Timer
General Description
The MAX8600/MAX8601 single-/dual-input linear battery chargers safely charge single-cell Li+ batteries.
The charging rate is optimized to accommodate the thermal characteristics of a given application. There is no need to reduce the maximum charge current or worst-case charger power dissipation. Charging is optimized for Li+ cells using a control algorithm that includes low-battery precharging, voltage and currentlimited fast-charging, and top-off charging, while continuously monitoring the battery for overvoltage, over/undertemperature, and charging time. The charger timeout protection is programmable. The charger status is indicated by three open-drain outputs. The MAX8601 automatically selects between either a USB or AC adapter input source. The AC adapter charge current is programmable, while USB charge current is set not to
- Battery Charge Voltage: 4.2 В
- Battery IC Case Style: TDFN
- Battery Type: Li-Ion
- Charge Current Max: 1 А
- Number of Series Cells: 2
- Входное напряжение: 14 В
- Количество выводов: 14
- RoHS: да
