Datasheet MAX8677AETG+ - Maxim Даташит USB/AC ADAPTER зарядное устройство, 1.5 А, 24TQFN — Даташит
Наименование модели: MAX8677AETG+
Купить MAX8677AETG+ на РадиоЛоцман.Цены — от 88 до 1 119 ₽43 предложений от 20 поставщиков Микросхема Чип управления батареи, MAXIM INTEGRATED PRODUCTS MAX8677AETG+ Battery Charger for 1 Cell of Li-Ion, Li-Pol battery, 6.6V input, 4.2V /... | |||
| MAX8677AETG+ Maxim | 173 ₽ | ||
| MAX8677AETG+TG24 Analog Devices | по запросу | ||
| MAX8677AETG+T | по запросу | ||
| MAX8677AETG+ Maxim | по запросу | ||
Производитель: Maxim
Описание: USB/AC ADAPTER зарядное устройство, 1.5 А, 24TQFN
19-0722; Rev 1; 1/07
EVALUATION KIT AVAILABLE
1.5A Dual-Input USB/AC Adapter Charger and Smart Power Selector
General Description
The MAX8677A is an integrated 1-cell Li+ charger and Smart Power SelectorTM with dual (DC and USB) power inputs.
It can operate with either separate inputs for USB and AC adapter power*, or from a single input that accepts both. All power switches for charging and switching the load between battery and external power are included on-chip. No external MOSFETs are required. The MAX8677A features a Smart Power Selector to make the best use of limited USB or adapter power. The battery charge current and input current limit are independently set up to 1.5A and 2A, respectively. Input power not used by the system charges the battery. USB input current can be set to 100mA or 500mA. Automatic input selection switches the system load from battery to external power. Other features include overvoltage protection (OVP), charge status and fault outputs, power-OK monito
- Battery Type: Li-Ion / Li-Polymer
- Входное напряжение: 6.6 В
- Battery Charge Voltage: 4.2 В
- Charge Current Max: 1.5 А
- Battery IC Case Style: TQFN
- Количество выводов: 24
- Number of Series Cells: 1
- Рабочий диапазон температрур: -40°C ... +85°C
- SVHC: No SVHC (18-Jun-2010)
- Тип корпуса: TQFN-EP
- Семейство: 8677
- Battery Management Function: Charger, Status Monitor
- Входное напряжение максимальное: 6.6 В
- Выходное напряжение максимальное: 4.242 В
- Способ монтажа: SMD
- Напряжения питания Vcc: 6.6 В
- Диапазон напряжения питания: 4.1 В ... 6.6 В
Дополнительные аксессуары:
- BONKOTE - BON102
- CHEMTRONICS - CW8400
- Electrolube - SMA10SL
