Datasheet MAX8677CETG+ - Maxim Даташит Зарядное устройство, HIGH VOLT, сдвоенный вход, SMD — Даташит
Наименование модели: MAX8677CETG+
Купить MAX8677CETG+ на РадиоЛоцман.Цены — от 59 до 1 076 ₽45 предложений от 21 поставщиков Зарядное устройство для 1-элементной литий-ионной, Li-Pol батареи, 6.6В вход, 4.2В/1.5A, TQFN-24 | |||
| MAX8677CETG+B4H Maxim | 61 ₽ | ||
| MAX8677CETG+B4H Rochester Electronics | 75 ₽ | ||
| MAX8677CETG+ Maxim | 179 ₽ | ||
| MAX8677CETG+ Maxim | от 1 076 ₽ | ||
Производитель: Maxim
Описание: Зарядное устройство, HIGH VOLT, сдвоенный вход, SMD
19-0781; Rev 0; 4/07
1.5A Dual-Input USB/AC Adapter Charger and Smart Power Selector
General Description
The MAX8677C is an integrated 1-cell Li+ charger and Smart Power SelectorTM with dual (DC and USB) power inputs.
It can operate with either separate inputs for USB and AC adapter power*, or from a single input that accepts both. All power switches for charging and switching the load between battery and external power are included on-chip. No external MOSFETs are required. The MAX8677C features a Smart Power Selector to make the best use of limited USB or adapter power. The battery charge current and input current limit are independently set up to 1.5A and 2A, respectively. Input power not used by the system charges the battery. USB input current can be set to 100mA or 500mA. Automatic input selection switches the system load from battery to external power. Other features include overvoltage protection (OVP), charge status and fault outputs, power-OK monitors, charge timer, and batt
- Battery Type: Li-Ion / Li-Polymer
- Входное напряжение: 6.6 В
- Battery Charge Voltage: 4.2 В
- Charge Current Max: 1.5 А
- Battery IC Case Style: TQFN
- Количество выводов: 24
- Number of Series Cells: 1
- Рабочий диапазон температрур: -40°C ... +85°C
- SVHC: No SVHC (18-Jun-2010)
- Тип корпуса: TQFN
- Семейство: 8677
- Battery Management Function: Charger, Source Selector
- Входное напряжение максимальное: 6.6 В
- Выходное напряжение максимальное: 4.242 В
- Способ монтажа: SMD
- Диапазон напряжения питания: 4.1 В ... 6.6 В
Дополнительные аксессуары:
- BONKOTE - BON102
- CHEMTRONICS - CW8400
- Electrolube - SMA10SL
