Datasheet MAX8934CETI+ - Maxim Даташит CHRGR, BATT, Вт TEMP MNTR, 4.35 В, 28TQFN — Даташит
Наименование модели: MAX8934CETI+
Купить MAX8934CETI+ на РадиоЛоцман.Цены — от 95 до 1 145 ₽17 предложений от 15 поставщиков Микросхема Чип управления батареи, Battery Monitoring Li-Ion/Li-Pol 1.5mA 4.2V 28Pin TQFN EP T/R | |||
| MAX8934CETI+T Maxim | 317 ₽ | ||
| MAX8934CETI+ Maxim | 687 ₽ | ||
| MAX8934CETI+ Maxim | по запросу | ||
| MAX8934CETI+ Analog Devices | по запросу | ||
Производитель: Maxim
Описание: CHRGR, BATT, Вт TEMP MNTR, 4.35 В, 28TQFN
19-4995; Rev 2; 6/10
TION KIT EVALUA BLE ILA AVA
Dual-Input Linear Chargers, Smart Power Selector with Advanced Battery Temperature Monitoring
General Description
The MAX8934_ dual-input Li+/Li-Poly linear battery chargers with Smart Power SelectorK safely charge a single Li+/Li-Poly cell in accordance with JEITA recommendations.
The MAX8934_ monitors the battery temperature (TBATT) while charging, and automatically adjusts the fast-charge current and charge termination voltage as the battery temperature varies. The MAX8934_ also monitors the battery temperature while the battery is discharging, and provides a warning flag (OT) to the system in the event that the battery is over temperature. Two safety profiles are supported (see Figure 6 for details). An ultra-low IQ, always-on LDO provides an additional 3.3V supply for system power. The MAX8934_ operates with either separate inputs for USB and AC adapter power*, or from a single input that accepts both. All power switches for charg
- Battery Charge Voltage: 4.35 В
- Battery IC Case Style: TQFN
- Battery Type: Li-Ion, Li-Polymer
- Charge Current Max: 500 мА
- Number of Series Cells: 1
- Влагостойкость: MSL 1 - Unlimited
- Количество выводов: 28
- Рабочий диапазон температрур: -40°C ... +85°C
- RoHS: да
