Datasheet MAX8934EETI+ - Maxim Даташит CHRGR, BATT, Вт TEMP MNTR, 4.35 В, 28TQFN — Даташит
Maxim MAX8934EETI+
Наименование модели: MAX8934EETI+
31 предложений от 17 поставщиков
Зарядное устройство для 1-элементной литий-ионной, Li-Pol батареи, вход, 4.35В/500мА
Рутоника
MAX8934EETI+
Maxim
187 ₽
MAX8934EETI+
Maxim
344 ₽
MAX8934EETI+
Maxim
MAX8934EETI+
Производитель: Maxim
Описание: CHRGR, BATT, Вт TEMP MNTR, 4.35 В, 28TQFN
data sheetСкачать Data Sheet
19-4995; Rev 2; 6/10
TION KIT EVALUA BLE ILA AVA
Dual-Input Linear Chargers, Smart Power Selector with Advanced Battery Temperature Monitoring
General Description
The MAX8934_ dual-input Li+/Li-Poly linear battery chargers with Smart Power SelectorK safely charge a single Li+/Li-Poly cell in accordance with JEITA recommendations.
The MAX8934_ monitors the battery temperature (TBATT) while charging, and automatically adjusts the fast-charge current and charge termination voltage as the battery temperature varies. The MAX8934_ also monitors the battery temperature while the battery is discharging, and provides a warning flag (OT) to the system in the event that the battery is over temperature. Two safety profiles are supported (see Figure 6 for details). An ultra-low IQ, always-on LDO provides an additional 3.3V supply for system power. The MAX8934_ operates with either separate inputs for USB and AC adapter power*, or from a single input that accepts both. All power switches for charg
  • Battery Charge Voltage: 4.35 В
  • Battery IC Case Style: TQFN
  • Battery Type: Li-Ion, Li-Polymer
  • Charge Current Max: 500 мА
  • Number of Series Cells: 1
  • Влагостойкость: MSL 1 - Unlimited
  • Количество выводов: 28
  • Рабочий диапазон температрур: -40°C ... +85°C
  • RoHS: да
На английском языке: Datasheet MAX8934EETI+ - Maxim CHRGR, BATT, W TEMP MNTR, 4.35 V, 28TQFN
