Datasheet MC34671AEPR2 - Freescale Даташит Зарядное устройство батареи аккумуляторов, SGL CELL, 8UDFN — Даташит
Наименование модели: MC34671AEPR2
![]() 41 предложений от 17 поставщиков Микросхема Чип управления батареи, NXP MC34671AEPR2 Battery Charger for 1 Cell of Li-Ion, Li-Pol battery, 10V input, 4.23V / 600mA charge,... | |||
MC34671AEPR2 NXP | 100 ₽ | ||
MC34671AEPR2 NXP | 180 ₽ | ||
MC34671AEPR2 NXP | от 245 ₽ | ||
MC34671AEPR2 Freescale | по запросу |
Производитель: Freescale
Описание: Зарядное устройство батареи аккумуляторов, SGL CELL, 8UDFN
Freescale Semiconductor Advance Information
Document Number: MC34671 Rev.
1.0, 01/2008
High Input Voltage 600mA Charger for Single-cell Li-Ion Batteries
34671
The MC34671 is a cost-effective fully-integrated battery charger for POWER MANAGEMENT IC Li-Ion or Li-Polymer batteries. The high input voltage, up to 28V, eliminates the input over-voltage-protection circuit required in handheld devices such as cell phones, Bluetooth accessories and MP3 players. A typical charge cycle includes trickle, constant-current (CC) and constant-voltage (CV) charge modes. The CC-mode current is programmable up to 600mA with an external resistor. The voltage across the external resistor is also used to monitor the actual charge EP SUFFIX (PB-FREE) 98ASA10774D current. The constant voltage is fixed at 4.2V with 0.7% accuracy over 8-PIN UDFN a -20°C to 70°C temperature range. The trickle-mode current is preset to 20% of the CC-mode current when the battery voltage is lower than the trickle-mode threshol
- Battery Type: Li-Ion / Li-Polymer
- Входное напряжение: 10 В
- Battery Charge Voltage: 4.23 В
- Charge Current Max: 600 мА
- Battery IC Case Style: UDFN
- Количество выводов: 8
- Number of Series Cells: 1
- Рабочий диапазон температрур: -40°C ... +85°C
- SVHC: No SVHC (20-Jun-2011)
- Семейство: 34671
- Battery Management Function: Charger, Status Monitor
- Control Interface: Parallel
- Входное напряжение максимальное: 10 В
- Выходное напряжение максимальное: 4.23 В
- Тип корпуса: UDFN
- Способ монтажа: SMD
- Диапазон напряжения питания: 2.6 В ... 10 В
