Datasheet MC34673AEPR2 - Freescale Даташит Зарядное устройство батареи аккумуляторов, SGL CELL, 8UDFN — Даташит
Freescale MC34673AEPR2
Наименование модели: MC34673AEPR2
32 предложений от 18 поставщиков
Микросхема Чип управления батареи, NXP MC34673AEPR2 Battery Charger for 1 Cell of Li-Ion, Li-Pol battery, 6.6V input, 4.23V / 1.2A charge,...
MC34673AEP/R2
48 ₽
Элитан
MC34673AEPR2
191 ₽
Контест
MC34673AEPR2
289 ₽
727GS
MC34673AEPR2
Производитель: Freescale
Описание: Зарядное устройство батареи аккумуляторов, SGL CELL, 8UDFN
data sheetСкачать Data Sheet
Freescale Semiconductor Advance Information
Document Number: MC34673 Rev.
1.0, 01/2008
High Input Voltage 1.2A Charger for Single-cell Li-Ion Batteries
The MC34673 is a cost-effective fully-integrated battery charger for Li-Ion or Li-Polymer batteries. The high input voltage, up to 28V, eliminates the input over-voltage protection circuit required in handheld devices such as PDAs, cell phones, portable video game players and digital still cameras. A typical charge cycle includes trickle, constant-current (CC) and constant-voltage (CV) charge modes. The CC-mode current is programmable up to 1.2A with an external resistor. The voltage across the external resistor is also used to monitor the actual charge current. The constant voltage is fixed at 4.2V with 0.7% accuracy over a -20°C to 70°C temperature range. The trickle-mode current is preset to 20% of the CC-mode current when the battery voltage is lower than the trickle-mode threshold. The end-of-charge (EOC) current threshold is pre
  • Battery Type: Li-Ion / Li-Polymer
  • Входное напряжение: 6.6 В
  • Battery Charge Voltage: 4.23 В
  • Charge Current Max: 1.2 А
  • Battery IC Case Style: UDFN
  • Количество выводов: 8
  • Number of Series Cells: 1
  • Рабочий диапазон температрур: -40°C ... +85°C
  • SVHC: No SVHC (20-Jun-2011)
  • Семейство: 34673
  • Battery Management Function: Charger, Status Monitor
  • Control Interface: Parallel
  • Входное напряжение максимальное: 6.6 В
  • Выходное напряжение максимальное: 4.23 В
  • Тип корпуса: UDFN
  • Способ монтажа: SMD
  • Диапазон напряжения питания: 2.6 В ... 6.6 В
На английском языке: Datasheet MC34673AEPR2 - Freescale BATTERY CHARGER, SGL CELL, 8UDFN
