Datasheet MC34674AEPR2 - Freescale Даташит Зарядное устройство батареи аккумуляторов, SGL CELL, 8UDFN — Даташит
Наименование модели: MC34674AEPR2
![]() 15 предложений от 15 поставщиков Микросхема Чип управления батареи, Battery Charger Li-Ion/Li-Pol 1050mA 4.2V 8Pin UDFN EP T/R | |||
MC34674AEP/R2 NXP | 50 ₽ | ||
MC34674AEPR2 NXP | 57 ₽ | ||
MC34674AEPR2 NXP | 107 ₽ | ||
MC34674AEPR2 Freescale | по запросу |
Производитель: Freescale
Описание: Зарядное устройство батареи аккумуляторов, SGL CELL, 8UDFN
Freescale Semiconductor Advance Information
Document Number: MC34674 Rev.
1.0, 01/2008
High Input Voltage Travel Charger for Single-cell Li-Ion Batteries
The MC34674 is a fully integrated single-cell Li-Ion and Li-Polymer battery charger optimized for travel charger applications. The few external components required include a dual-color LED for chargestatus indication, a negative temperature coefficient (NTC) thermistor circuit for setting the charge temperature window, and two decoupling capacitors. The high input voltage, up to 28V, allows low-cost ac/dc converters to be used for further system cost reduction. A typical charge cycle of the MC34674 includes trickle, constant-current (CC) and constant-voltage (CV) charge modes. The CC-mode current is selectable from 50mA to 1.05A with 8% accuracy and the constantoutput voltage in the CV-mode is fixed at 4.2V with 0.4% accuracy over -20°C to 70°C temperature range. The MC34674 has all the features such as trickle charging for a deeply
- Battery Type: Li-Ion / Li-Polymer
- Входное напряжение: 10 В
- Battery Charge Voltage: 4.2 В
- Charge Current Max: 1050 мА
- Battery IC Case Style: UDFN
- Количество выводов: 8
- Number of Series Cells: 1
- Рабочий диапазон температрур: -40°C ... +85°C
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: UDFN
- Семейство: 34674
- Battery Management Function: Charger, Status Monitor
- Control Interface: Parallel
- Входное напряжение максимальное: 10 В
- Выходное напряжение максимальное: 4.221 В
- Способ монтажа: SMD
- Диапазон напряжения питания: 4.3 В ... 10 В
