Datasheet XC6802A42XER-G - Torex Даташит ИС, зарядное устройство батареи аккумуляторов, LI-ION, USP-6C — Даташит
Torex XC6802A42XER-G
Наименование модели: XC6802A42XER-G
34 предложений от 16 поставщиков
Микросхема Чип управления батареи, Battery Charger/Constant Current/Constant Voltage Li-Ion 800mA 4.2V 6Pin USP T/R
XC6802A42XER-G
Torex
22 ₽
XC6802A42XER-G
Torex
35 ₽
XC6802A42XER-G
71 ₽
ЗУМ-СМД
XC6802A42XER-G
Torex
Производитель: Torex
Описание: ИС, зарядное устройство батареи аккумуляторов, LI-ION, USP-6C
data sheetСкачать Data Sheet
XC6802 Series
1 Cell Li-ion Battery Linear Charger IC with Constant-Current/Constant-Voltage
ETR2501-005b
GENERAL DESCRIPTION
The XC6802 series is a constant-current/constant-voltage linear charger IC for single cell lithium-ion batteries.
The XC6802 includes a reference voltage source, battery voltage monitor, driver transistor, constant-current/constant-voltage charge circuit, over heat protection circuit, phase compensation circuit. The battery charge termination voltage is internally set to 4.2V 0.7% and the trickle charge voltage and accuracy is 2.9V 3%. In trickle charge mode, a safe charge to a battery is possible because approximately 1/10 out of setting charge current is supplied to the battery. With an external RSEN resistor, the charge current can be set freely up to 800mA (MAX.), therefore, the series is ideal for various battery charge applications. The series' charge status output pin, /CHG pin, is capable of checking the IC's charging state while connecting with an ext
  • Battery Type: Li-Ion
  • Входное напряжение: 6 В
  • Battery Charge Voltage: 2.9 В
  • Charge Current Max: 800 мА
  • Battery IC Case Style: USP-6C
  • Количество выводов: 6
  • Number of Series Cells: 1
  • Рабочий диапазон температрур: -40°C ... +85°C
  • SVHC: No SVHC (15-Dec-2010)
  • Семейство: 6802
Дополнительные аксессуары:
  • MULTICORE (SOLDER) - 698840
XC6802A42XERG, XC6802A42XER G
На английском языке: Datasheet XC6802A42XER-G - Torex IC, BATTERY CHARGER, LI-ION, USP-6C
