Datasheet LT1513-2CT7 - Linear Technology Даташит ИС, зарядное устройство батареи аккумуляторов, 2 А, TO-220-7 — Даташит
Наименование модели: LT1513-2CT7
![]() 36 предложений от 17 поставщиков Микросхема Чип управления батареи, LINEAR TECHNOLOGY LT1513-2CT7#PBF Battery Charger for 1 Cell of Lead Acid, Li-Ion, NiCd, NiMH battery, 25Vin, 20V/2A... | |||
LT1513-2CT7#PBF Linear Technology | от 266 ₽ | ||
LT1513-2CT7#PBF Analog Devices | 1 116 ₽ | ||
LT1513-2CT7 Analog Devices | 2 042 ₽ | ||
LT1513-2CT7#PBF Analog Devices | по запросу |
Производитель: Linear Technology
Описание: ИС, зарядное устройство батареи аккумуляторов, 2 А, TO-220-7
LT1513/LT1513-2 SEPIC Constant- or Programmable-Current/ Constant-Voltage Battery Charger
FEATURES
s s s
DESCRIPTION
The LT ®1513 is a 500kHz current mode switching regulator specially configured to create a constant- or programmable-current/constant-voltage battery charger.
In addition to the usual voltage feedback node, it has a current sense feedback circuit for accurately controlling output current of a flyback or SEPIC (Single-Ended Primary Inductance Converter) topology charger. These topologies allow the current sense circuit to be ground referred and completely separated from the battery itself, simplifying battery switching and system grounding problems. In addition, these topologies allow charging even when the input voltage is lower than the battery voltage. The LT1513 can also drive a CCFL Royer converter with high efficiency in floating or grounded mode. Maximum switch current on the LT1513 is 3A. This allows battery charging currents up to 2A for a single lithium-ion ce
- Battery Type: Lead Acid, Li-Ion, NiCd, NiMH
- Входное напряжение: 25 В
- Battery Charge Voltage: 20 В
- Charge Current Max: 2 А
- Battery IC Case Style: TO-220
- Количество выводов: 7
- Number of Series Cells: 1
RoHS: Y-Ex
LT15132CT7, LT1513 2CT7
