Клеммные колодки Keen Side
Datasheet LT3650EDD-4.2 - Linear Technology Даташит ИС, зарядное устройство батареи аккумуляторов, 2 А, DFN-12 — Даташит
Linear Technology LT3650EDD-4.2
Наименование модели: LT3650EDD-4.2
31 предложений от 18 поставщиков
Микросхемы Зарядных Устройств
LT3650EDD-4.2#PBF
222 ₽
ЭИК
LT3650EDD-4.2#PBF
от 836 ₽
ТаймЧипс
LT3650EDD-4.2#TRPBF
LT3650EDD-4.2
Производитель: Linear Technology
Описание: ИС, зарядное устройство батареи аккумуляторов, 2 А, DFN-12
data sheetСкачать Data Sheet
LT3650-4.1/LT3650-4.2 High Voltage 2 Amp Monolithic Li-Ion Battery Charger FEATURES
n n n n n n n n n n n n n n n n n
DESCRIPTION
The LT®3650 is a complete monolithic single-cell Li-Ion/ Polymer battery charger that operates over a 4.75V to 32V input voltage range (7.5V minimum start-up voltage).
The LT3650 provides a constant-current/constant-voltage charge characteristic, with maximum charge current externally programmable up to 2A, set using an external current sense resistor. A precondition feature tricklecharges a low voltage battery, and bad-battery detection provides a signal and suspends charging if a battery does not respond to preconditioning. The LT3650 can be configured to terminate charging when charge current falls to C/10, or one-tenth the programmed maximum current. Once charging is terminated, the LT3650 enters a low current (85A) standby mode. An auto-restart feature starts a new charging cycle if the battery voltage drops 2.5% from the float voltage, or if a new bat
  • Battery Type: Li-Ion, Li-Polymer
  • Входное напряжение: 32 В
  • Battery Charge Voltage: 4.2 В
  • Charge Current Max: 2 А
  • Battery IC Case Style: DFN
  • Количество выводов: 12
  • Number of Series Cells: 2
LT3650EDD4.2, LT3650EDD 4.2
На английском языке: Datasheet LT3650EDD-4.2 - Linear Technology IC, BATTERY CHARGER, 2 A, DFN-12
