Datasheet LTC4070EDDB - Linear Technology Даташит ИС, зарядное устройство батареи аккумуляторов, 50 мА, DFN-8 — Даташит
Linear Technology LTC4070EDDB
Наименование модели: LTC4070EDDB
25 предложений от 17 поставщиков
Shunt Battery Charger Li-Ion/Li-Pol 50mA 4V/4.1V/4.2V Automotive 8-Pin DFN EP T/R / IC BATT CHRGR LIION/POLY 8DFN
LTC4070EDDB#TRPBF
192 ₽
Элитан
LTC4070EDDB
648 ₽
LTC4070EDDB#PBF
МосЧип
LTC4070EDDB#TRMPBF
Производитель: Linear Technology
Описание: ИС, зарядное устройство батареи аккумуляторов, 50 мА, DFN-8
data sheetСкачать Data Sheet
LTC4070 Li-Ion/Polymer Shunt Battery Charger System FEATURES
n n n n n n n n n
DESCRIPTION
The LTC®4070 allows simple charging of Li-Ion/Polymer batteries from very low current, intermittent or continuous charging sources.
The 450nA to 50mA operating current makes charging possible from previously unusable sources. With the addition of an external pass device, shunt current may be boosted to 500mA. Stacked cell high voltage battery packs are inherently balanced with shunt charging. With its low operating current, the LTC4070 is well suited to charge thin film batteries in energy harvesting applications where charging sources may be intermittent or very low power. The unique architecture of the LTC4070 allows for an extremely simple battery charger solution; requiring just one external resistor. The LTC4070 offers a pin selectable float voltage with 1% accuracy across the full range of operating temperature and shunt current. The integrated thermal battery qualifier extends battery lif
  • Battery Type: Li-Ion, Li-Polymer
  • Battery Charge Voltage: 4.2 В
  • Charge Current Max: 50 мА
  • Battery IC Case Style: DFN
  • Количество выводов: 8
  • Number of Series Cells: 1
  • Рабочий диапазон температрур: -40°C ... +85°C
Дополнительные аксессуары:
  • Linear Technology - LTC3588EDD-1#PBF.
  • Linear Technology - LTC3588EMSE-1#PBF.
  • Linear Technology - LTC3588IMSE-1#PBF.
На английском языке: Datasheet LTC4070EDDB - Linear Technology IC, BATTERY CHARGER, 50 mA, DFN-8
