Datasheet LTC4160EUDC - Linear Technology Даташит ИС, BATT CHRG, Li-Ion, Li-Polymer, 1.2 А, QFN20 — Даташит
Наименование модели: LTC4160EUDC
![]() 32 предложений от 16 поставщиков Микросхема Чип управления батареи, LINEAR TECHNOLOGY LTC4160EUDC#PBF Battery Charger for 1 Cell of Li-Ion, Li-Pol battery, 5.5V input, 1.2A charge, QFN-20... | |||
LTC4160EUDC#PBF Analog Devices | от 124 ₽ | ||
LTC4160EUDC#PBF Analog Devices | 222 ₽ | ||
LTC4160EUDC-1#PBF Linear Technology | по запросу | ||
LTC4160EUDC TRPBF Linear Technology | по запросу |
Производитель: Linear Technology
Описание: ИС, BATT CHRG, Li-Ion, Li-Polymer, 1.2 А, QFN20
FEATURES
n
LTC4160/LTC4160-1 Switching Power Manager with USB On-The-Go And Overvoltage Protection DESCRIPTION
The LTC®4160/LTC4160-1 are high efficiency power management and Li-Ion/Polymer battery charger ICs.
They each include a bidirectional switching PowerPathTM controller with automatic load prioritization, a battery charger, and an ideal diode. The LTC4160/LTC4160-1's bidirectional switching regulator transfers nearly all of the power available from the USB port to the load with minimal loss and heat which eases thermal constraints in small spaces. These devices feature a precision input current limit for USB compatibility and Bat-Track output control for efficient charging. In addition, the ICs can also generate 5V at 500mA for USB On-TheGo applications. An overvoltage circuit protects the LTC4160/LTC4160-1 from high voltage damage on the USB/wall adapter inputs with an external N-channel MOSFET and a resistor. The LTC4160/LTC4160-1 are available in a 3mm Ч 4mm Ч 0.75mm QFN sur
- Battery Type: Li-Ion, Li-Polymer
- Входное напряжение: 5.5 В
- Battery Charge Voltage: 4.2 В
- Charge Current Max: 1.2 А
- Battery IC Case Style: QFN
- Количество выводов: 20
- Number of Series Cells: 1
