Datasheet MC33341PG - ON Semiconductor Даташит ИС, зарядное устройство батареи аккумуляторов, NICD, NIMH, DIP-8 — Даташит
Наименование модели: MC33341PG
10 предложений от 10 поставщиков IC CTRLR BATTERY FAST CHRG 8DIP. Charger IC 8-PDIP. PMIC - Battery Chargers | |||
| MC33341PG ON Semiconductor | 65 ₽ | ||
| MC33341PG ON Semiconductor | по запросу | ||
Производитель: ON Semiconductor
Описание: ИС, зарядное устройство батареи аккумуляторов, NICD, NIMH, DIP-8
MC33341 Power Supply Battery Charger Regulation Control Circuit
The MC33341 is a monolithic regulation control circuit that is specifically designed to close the voltage and current feedback loops in power supply and battery charger applications.
This device features the unique ability to perform source high-side, load high-side, source low-side and load low-side current sensing, each with either an internally fixed or externally adjustable threshold. The various current sensing modes are accomplished by a means of selectively using the internal differential amplifier, inverting amplifier, or a direct input path. Positive voltage sensing is performed by an internal voltage amplifier. The voltage amplifier threshold is internally fixed and can be externally adjusted in all low-side current sensing applications. An active high drive output is provided to directly interface with economical optoisolators for isolated output power systems. This device is available in 8-lead dual-in-line and
Купить MC33341PG на РадиоЛоцман.Цены
