Datasheet Texas Instruments UC3906DW — Даташит
СерияUC3906
МодельUC3906DW
Зарядное устройство для линейных свинцово-кислотных аккумуляторов 16-SOIC от -20 до 70
Sealed Lead-Acid Battery Charger datasheet
PDF, 4.3 Мб, Версия: C, Файл опубликован: 23 май 2005
Pin16
Package TypeDW
Package QTY40
МаркировкаUC3906DW
Width (мм)7.5
Length (мм)10.3
Thickness (мм)2.35
Max Height (мм)2.65
Рекомендуемая замена
ReplacementBQ24450DW
Replacement CodeF
  • U-104 Improved Charging Methods for Lead-Acid Batteries Using the UC3906
    PDF, 331 Кб, Файл опубликован: 5 сен 1999
    This application note describes the operation and application of the UC3906 sealed lead-acid battery-charger IC. Several charging circuits using this IC are described, along with expected improvements in battery performance. This note also discusses uses for the many auxiliary functions of the part.
  • U-131 Simple Switchmode Lead-Acid Battery Charger
    PDF, 206 Кб, Файл опубликован: 5 сен 1999
    Lead-acid batteries are finding considerable use as bothprimary and backup power sources. For complete batteryutilization the charger circuit must charge the batteryto full capacity while minimizing over-charging forextended battery life. Since battery capacity varies withtemperature the charger must vary the amount of chargewith temperature to realize maximum capacity and life.Si
  • Semiconductors > Power Management > Battery Management Products > Battery Charger IC
На английском языке: Datasheet Texas Instruments UC3906DW
