Datasheet Texas Instruments BQ24703PWG4 — Даташит
СерияBQ24703
МодельBQ24703PWG4
Многохимический контроллер заряда аккумулятора и переключатель мощности системы 24-TSSOP от -40 до 125
Multichemistry Battery Charger Controller & System Power Selector datasheet
PDF, 880 Кб, Версия: E, Файл опубликован: 18 окт 2007
Pin24
Package TypePW
Industry STD TermTSSOP
Package QTY60
Маркировка24703PW
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
Absolute Vin (safety rating)(Max)(30 В
Battery Charge Voltage(Max)16.8 В
Battery Charge Voltage(Min)8.4 В
Cell ChemistryLi-Ion/Li-Polymer
Charge Current(Max)10 A
Control InterfaceStandalone (RC-Settable)
Control TopologySwitch-Mode Buck
Number of Series Cells2,3,4
Operating Vin(Max)28 В
Operating Vin(Min)7 В
Package GroupTSSOP
Package Size: mm2:W x L24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP) PKG
Special FeaturesPower Path
USB FeatureN/A
  • Evaluation Modules & Boards: BQ24703EVM
    BQ24703 Evaluation Module
  • Designing a multichemistry battery charger
    PDF, 508 Кб, Файл опубликован: 4 окт 2009
  • How to Review a Multicell Switching Charger Schematic
    PDF, 196 Кб, Файл опубликован: 21 сен 2011
    This application report provides a checklist for reviewing a switching charger schematic and explains each item in the list.
  • Dynamic Power-Path Mgmt & Dynamic Power Mgmt
    PDF, 96 Кб, Файл опубликован: 2 янв 2007
    Dynamic power-path management (DPPM) and dynamic power management (DPM) are two similar types of integrated power management ICs that combine the task of charging a single-cell Li-ion battery and powering the system. Both topologies reduce the battery charging current to give the system priority when the adaptor has reached its output current rating. The bq2403x family and TPS65800 IC use the DPP
  • Q4 2009 Issue Analog Applications Journal
    PDF, 1.5 Мб, Файл опубликован: 4 окт 2009
  • Semiconductors > Power Management > Battery Management Products > Battery Charger IC
На английском языке: Datasheet Texas Instruments BQ24703PWG4
