Datasheet LT1769CGN - Linear Technology Даташит ИС, BATT зарядное устройство, SMD, SSOP28, 1769 — Даташит
Наименование модели: LT1769CGN
Купить LT1769CGN на РадиоЛоцман.Цены — от 227 до 1 938 ₽27 предложений от 21 поставщиков Микросхема Чип управления батареи, LINEAR TECHNOLOGY LT1769CGN#PBF Battery Charger for Li-Ion, NiCd, NiMH battery, 28V input, 25V/2A charge, SSOP-28 | |||
| LT1769CGN Analog Devices | 342 ₽ | ||
| LT1769CGN#TRPBF Analog Devices | 506 ₽ | ||
| LT1769CGN#PBF Analog Devices | от 1 739 ₽ | ||
| LT1769CGN Analog Devices | по запросу | ||
Производитель: Linear Technology
Описание: ИС, BATT зарядное устройство, SMD, SSOP28, 1769
FEATURES
s
LT1769 Constant-Current/ Constant-Voltage 2A Battery Charger with Input Current Limiting DESCRIPTIO
The LT®1769 current mode PWM battery charger is a simple, efficient solution to fast charge modern rechargeable batteries including lithium-ion (Li-Ion), nickel-metalhydride (NiMH) and nickel-cadmium (NiCd) that require constant-current and/or constant-voltage charging.
The internal switch is capable of delivering 2A** DC current (3A peak current). Charge current can be programmed by resistors or a DAC to within 5%. With 0.5% reference voltage accuracy, the LT1769 meets the critical constant-voltage charging requirement for Li-Ion cells. A third control loop is provided to regulate the current drawn from the input AC adapter. This allows simultaneous operation of the equipment and battery charging without overloading the adapter. Charge current is reduced to keep the adapter current below specified levels. The LT1769 can charge batteries ranging from 1V to 20V. Ground sensing
- Battery Type: Li-Ion, NiCd, NiMH
- Входное напряжение: 28 В
- Battery Charge Voltage: 20 В
- Charge Current Max: 2 А
- Battery IC Case Style: SSOP
- Количество выводов: 28
- Рабочий диапазон температрур: 0°C ... +125°C
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: SSOP
- Семейство: 1769
- Выходной ток максимальный: 3 А
- Выходное напряжение максимальное: 25 В
- Способ монтажа: SMD
- Device Type: Power
- Количество выходов: 1
- Output Source Current Max: 1.1 мА
- Диапазон напряжения питания: 8 В ... 30 В
Дополнительные аксессуары:
- Electrolube - HTS35SL
- Fischer Elektronik - ICK SMD A 5 SA
- Roth Elektronik - RE931-05
- STANNOL - 631954
