Datasheet MAX17005ETP+ - Maxim Даташит ИС, зарядное устройство батареи аккумуляторов, 4 А, TQFN-20 — Даташит
Maxim MAX17005ETP+
Наименование модели: MAX17005ETP+
16 предложений от 16 поставщиков
Микросхема Чип управления батареи, Battery Management 1.2MHz High-Perf Charger
MAX17005ETP+
671 ₽
Рутоника
MAX17005ETP+T
Maxim
MAX17005ETP+T
MAX17005ETP+
Maxim
Производитель: Maxim
Описание: ИС, зарядное устройство батареи аккумуляторов, 4 А, TQFN-20
data sheetСкачать Data Sheet
19-4041; Rev 0; 2/08
KIT ATION EVALU BLE AVAILA
1.2MHz Low-Cost, High-Performance Chargers
General Description Features
High Switching Frequency (1.2MHz) Controlled Inductor Current-Ripple Architecture Reduced BOM Cost Small Inductor and Output Capacitors ±0.4% Accurate Charge Voltage ±2.5% Accurate Input-Current Limiting ±3% Accurate Charge Current Single-Point Compensation Monitor Outputs for ±2.5% Accurate Input Current Limit ±2.5% Battery Discharge Current (MAX17015 only) AC Adapter Detection Analog/PWM Adjustable Charge-Current Setting Battery Voltage Adjustable for 3 and 4 Cells (MAX17005) or 2 and 3 Cells (MAX17006) Adjustable Battery Voltage (4.2V to 4.4V/Cell) Cycle-by-Cycle Current Limit Battery Short-Circuit Protection Fast Response for Pulse Charging Fast System-Load-Transient Response Programmable Charge Current < 5A Automatic System Power Source Selection with n-Channel MOSFET Internal Boost Diode +8V to +26V Input Voltage Range
  • Battery Charge Voltage: 19 В
  • Battery IC Case Style: TQFN
  • Battery Type: Li-Ion, NiCd, NiMH
  • Charge Current Max: 4 А
  • Number of Series Cells: 4
  • Входное напряжение: 26 В
  • Количество выводов: 20
  • RoHS: да
На английском языке: Datasheet MAX17005ETP+ - Maxim IC, BATTERY CHARGER, 4 A, TQFN-20
