Datasheet MC33342DG - ON Semiconductor Даташит CHARGE контроллер FOR BATT, SOIC8 — Даташит
ON Semiconductor MC33342DG
Наименование модели: MC33342DG
Микросхема Чип управления батареи, Battery Fast Charge Controllers
MC33342DG
21 ₽
MC33342DG
MC33342DG
MC33342DG
Производитель: ON Semiconductor
Описание: CHARGE контроллер FOR BATT, SOIC8
data sheetСкачать Data Sheet
MC33340, MC33342 Battery Fast Charge Controllers
The MC33340 and MC33342 are monolithic control IC's that are specifically designed as fast charge controllers for Nickel Cadmium (NiCd) and Nickel Metal Hydride (NiMH) batteries.
These devices feature negative slope voltage detection as the primary means for fast charge termination. Accurate detection is ensured by an output that momentarily interrupts the charge current for precise voltage sampling. An additional secondary backup termination method can be selected that consists of either a programmable time or temperature limit. Protective features include battery over and undervoltage detection, latched over temperature detection, and power supply input undervoltage lockout with hysteresis. Fast charge holdoff time is the only difference between the MC33340 and the MC33342. The MC33340 has a typical holdoff time of 177 seconds and the MC33342 has a typical holdoff time of 708 seconds. · Negative Slope Voltage Detection with 4.0 mV Sens
  • Battery Type: NiCd / NiMH
  • Входное напряжение: 18 В
  • Battery Charge Voltage: 20 В
  • Battery IC Case Style: SOIC
  • Количество выводов: 8
  • Рабочий диапазон температрур: -20°C ... +85°C
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: SOIC
  • Семейство: 33342
  • Battery Management Function: Charge Controller
  • Входное напряжение максимальное: 18 В
  • Способ монтажа: SMD
  • Диапазон напряжения питания: 3.25 В ... 18 В
Дополнительные аксессуары:
  • Electrolube - HTS35SL
  • Fischer Elektronik - ICK SMD A 10 SA
  • Roth Elektronik - RE932-01
  • STANNOL - 574601
На английском языке: Datasheet MC33342DG - ON Semiconductor CHARGE CONTROLLER FOR BATT, SOIC8
