Оптопары и оптореле Megawin
Datasheet Texas Instruments BQ20Z90DBT-V110 — Даташит
СерияBQ20Z90-V110
МодельBQ20Z90DBT-V110
Датчик газа, соответствующий стандарту SBS 1.1, с технологией отслеживания импеданса 30-TSSOP от -40 до 125
SBS v1.1 Compliant Gas Gauge for Use With the bq29330 datasheet
PDF, 952 Кб, Файл опубликован: 20 окт 2006
Pin30
Package TypeDBT
Industry STD TermTSSOP
Package QTY60
МаркировкаBQ20Z90DBT
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
  • Evaluation Modules & Boards: BQ20Z90EVM-001
    BQ20Z90EVM Evaluation Module for 2nd Generation Impedance TrackВ™
  • Evaluation Modules & Boards: BQMTESTER
    BQMTESTER Multi Channel Test and Program Board
  • Evaluation Modules & Boards: BQTESTER
    Single Channel Tester
  • Cell-type Specific Settings for Cell Imbalance Permanent Failure Thresholds
    PDF, 100 Кб, Файл опубликован: 28 сен 2007
  • 2-Series-Cell Considerations for Advanced Fuel Gauges
    PDF, 154 Кб, Файл опубликован: 9 май 2008
  • Operating Fuel Gauge bq20z7x/8x/9x and SMBus-Like bq24745/47/65 Chargers
    PDF, 132 Кб, Файл опубликован: 6 окт 2009
    The smart charger bq24747/765 is a high-efficiency, synchronous battery charger with an integrated input current comparator. This charger provides low component count for space constrained, multichemistry battery charging applications. SMBus input current, charge current, and input current digital-to-analog converters allow for very high regulation accuracies that the system power management micr
  • Cell Balancing Using the bq20zxx (Rev. C)
    PDF, 208 Кб, Версия: C, Файл опубликован: 12 янв 2011
    This application report discusses three types of cell imbalances that are observed in a battery pack withserially connected cells.
  • Updating Firmware With the bq20zxx and EVM (Rev. B)
    PDF, 54 Кб, Версия: B, Файл опубликован: 7 ноя 2006
    This application report presents the steps necessary to update the bq20z80 firmware and the EVM.
  • bq20z80 EVM Data Flash Settings for Num of Serial Cells/Pack Cap (Rev. B)
    PDF, 1.1 Мб, Версия: B, Файл опубликован: 6 ноя 2006
    This application report describes the configuration changes in the data flash constants in the Texas Instruments bq20z80 Gas Gauge Evaluation Software for a variety of battery-pack configurations.
  • Pack Assembly and the bq20zxx (Rev. B)
    PDF, 35 Кб, Версия: B, Файл опубликован: 7 ноя 2006
    This application report describes a recommended assembly sequence for the bq20z80-based battery pack. This procedure results in the most time-efficient setup of the battery pack. Included are steps for connecting a 4-series cell battery to the bq20z80EVM-001.
  • Thermistor Coefficient Calculator for TI Advanced Fuel Gauges
    PDF, 58 Кб, Файл опубликован: 4 окт 2006
  • Design 4: Support of Multiple Li-Ion Chemistries w/Impedance Track(TM) Gas Gauge (Rev. R)
    PDF, 87 Кб, Версия: R, Файл опубликован: 15 окт 2009
  • bq20z70 and bq20z90 Application Book
    PDF, 14.2 Мб, Файл опубликован: 13 дек 2006
    This document introduces the bq20z70/z90 Impedance Trackв„ў and bq29330 chipset gas gauge solution
  • Quick-Start Guide for bq20zxx Family Gas Gauges (Rev. A)
    PDF, 4.4 Мб, Версия: A, Файл опубликован: 4 сен 2007
    The intent of this application report is to give the user an overview of the design process, how to use the evaluation module and software, and to provide helpful troubleshooting techniques.This document begins with setting up the evaluation module and working with bq Evaluation Software. Several tips for troubleshooting the software connection are included, as well as navigation and what to l
  • Semiconductors > Power Management > Battery Management Products > Battery Fuel Gauge
BQ20Z90DBTV110, BQ20Z90DBT V110
На английском языке: Datasheet Texas Instruments BQ20Z90DBT-V110
