Datasheet Texas Instruments BQ27541DRZT — Даташит
СерияBQ27541
МодельBQ27541DRZT
Указатель уровня топлива одноэлементной литий-ионной батареи для интеграции аккумуляторной батареи 12-SON от -40 до 85
Single Cell Li-Ion Battery Fuel Gauge for Battery Pack Integration datasheet
PDF, 1.1 Мб, Файл опубликован: 10 дек 2008
Pin1212
Package TypeDRZDRZ
Industry STD TermVSONVSON
JEDEC CodeS-PDSO-NS-PDSO-N
Package QTY250250
CarrierSMALL T&RSMALL T&R
Маркировка7541BQ
Width (мм)2.52.5
Length (мм)44
Thickness (мм).85.85
Pitch (мм).4.4
Max Height (мм)11
Рекомендуемая замена
ReplacementBQ27542DRZT-G1
Replacement CodeS
  • Evaluation Modules & Boards: BQ27541EVM
    Single Cell Impedance TrackВ™ Battery Fuel Gauge With LDO Evaluation Module | Gas Gauge
  • ESD and RF Mitigation in Handheld Battery Pack Electronics
    PDF, 68 Кб, Файл опубликован: 6 мар 2008
    It is imperative to protect the electronics in a consumer-removable battery pack from ESD damage. Even an upset without permanent damage may be unacceptable to the end-user. Handheld equipment that contains a transmitter also may require protection to guard against improper measurement and/or upset due to the affect of the radio frequency (RF) on the circuitry. Because the RF field strength varies
  • Going to Production With the bq2754x (Rev. A)
    PDF, 581 Кб, Версия: A, Файл опубликован: 11 мар 2011
    This application report presents a strategy for high speed, economical calibration, and production programming of the bq2754x single-cell gas gauge. Flowchart examples are provided, along with step-by-step instructions for preparing a calibration data set that is required when creating the golden data flash image (DFI) that is programmed into all bq2754x at the pack maker production line.
  • Configuring the bq2754x Data Flash
    PDF, 1.2 Мб, Файл опубликован: 27 май 2009
    The bq2754x has many data flash constants that can configure the device with various, different options for most features. The data flash of the bq2754x is divided into sections, which are described in detail in this document.
  • bq27541 to bq27541-v200 Change List
    PDF, 40 Кб, Файл опубликован: 17 фев 2010
    This document describes the design changes from the bq27541 (firmware version 1.12) to bq27541-v200 (firmware version 2.00). For ordering information and data sheet, see the Texas Instruments Web site.
  • bq27541-v200 to bq27541-G1 Change List (Rev. A)
    PDF, 43 Кб, Версия: A, Файл опубликован: 21 окт 2012
    bq27541-v200, bq27541-G1 bq27541-v200 to bq27541-G1 CHANGE LIST PMP/BMS/Handheld/2-App_Reports/SLUA641_Change_List/bq27541-v200_ChangeList
  • Fine tuning TI's Impedance Trackв„ў battery fuel gauge with LiFePO4 cells
    PDF, 153 Кб, Файл опубликован: 14 мар 2011
  • Thermistor Selection Guide for Texas Instruments Advanced Fuel Gauges
    PDF, 564 Кб, Файл опубликован: 28 сен 2011
    bq20z40, bq20z45, bq20z60, bq20z65, bq20z70, bq20z75, bq20z80, bq20z90, bq20z95, bq27410, Thermistor Selection Guide for Texas Instruments Advanced Fuel Guages
  • WinCE/Linux Drivers for bq275xx Fuel Gauge
    PDF, 188 Кб, Файл опубликован: 17 мар 2011
    The bq275xx gas gauge integrated circuits (IC) can use an I2C line for communication with the host system. It is necessary to allow application-layer software on the host system to access parameters made available by the gas gauge IC. Multiple levels of abstraction are between the gauge and a given application. This document describes an example implementation of each of these layers in an effo
  • How to Transfer bq27541 Into Hibernate Mode
    PDF, 42 Кб, Файл опубликован: 13 апр 2010
    This document presents a checklist and a discussion on how to transfer reliably the bq27541 into Hibernate mode.
  • Selecting an Impedance Track Gas Gauge for Li-Ion Single Cell Applications
    PDF, 78 Кб, Файл опубликован: 10 апр 2012
  • Updating bq275xx Firmware at Production (Rev. A)
    PDF, 107 Кб, Версия: A, Файл опубликован: 21 фев 2011
    bq27500 bq27500-V100 bq27500-V120 bq27500-V130 bq27501 bq27505 bq27505-J2 bq27505-J3 bq275 Updating bq275xx Firmware at Production
  • Improving Battery Safety, Charging, and Fuel Gauging in Portable Media Apps
    PDF, 570 Кб, Файл опубликован: 11 мар 2009
  • Updating Firmware with the bq2750x and EVM (Rev. A)
    PDF, 955 Кб, Версия: A, Файл опубликован: 22 июл 2008
    This application report provides the procedure to update bq2750x firmware and the learned golden image (*.DFI file) in bq27500 data flash from the previous firmware version.
  • Gauge Communication
    PDF, 79 Кб, Файл опубликован: 12 янв 2017
  • How to Generate Golden Image for Single-Cell Impedance Track(TM) Devices
    PDF, 964 Кб, Файл опубликован: 7 янв 2010
    Texas Instruments advanced fuel gauges, employing the Impedance Trackв„ў algorithm, offer an unmatched array of features and benefits. Sometimes, however, the learning cycle to generate the golden image may seem a little challenging. In addition, determining the correct chemistry model and producing the golden image file can be time consuming. This application report describes the necessary p
  • Impedance Track Fuel Gauge Accuracy Test for GSM Phone Applications
    PDF, 393 Кб, Файл опубликован: 21 мар 2008
    The Texas Instruments Impedance Trackв„ў (IT) fuel gauge is designed for reporting remaining battery capacity and run time accurately. To effectively accomplish this reporting a real application environment must be used for test results. The test board should be designed as similar to the real application circuit as possible. This application report outlines the procedure for implementing an accurac
  • Using I2C Communication With the bq275xx Series of Fuel Gauges (Rev. B)
    PDF, 53 Кб, Версия: B, Файл опубликован: 15 май 2014
  • Configuring the bq27541-V200 Data Flash (Rev. B)
    PDF, 1.5 Мб, Версия: B, Файл опубликован: 9 мар 2011
  • Achieving the Successful Learning Cycle
    PDF, 46 Кб, Файл опубликован: 12 май 2011
    bq27500, bq27501, bq27510, bq27505, bq27541, bq27520 Achieving the Successful Learning Cycle
  • Theory and Implementation of Impedance Track Battery Fuel-Gauging Algorithm
    PDF, 608 Кб, Файл опубликован: 31 янв 2008
    This application report outlines the theory of Impedance Trackв„ў (IT) technology used in the bq2750x series of fuel gauge ICs for single-cell Li-ion applications (e.g., smart phones, media players, and PDAs). The implementation of the IT algorithm in the bq2750x family is reviewed, and the settings of data flash constants associated with the fuel-gauging algorithm is described in detail.
  • Single Cell Impedance Track Printed-Circuit Board Layout
    PDF, 403 Кб, Файл опубликован: 22 фев 2008
    bq20z70/90 Printed-Circuit Board Layout Guide
  • Single Cell Gas Gauge Circuit Design
    PDF, 154 Кб, Файл опубликован: 22 фев 2008
  • Configuring the bq2754x-G1 Data Flash
    PDF, 1.1 Мб, Файл опубликован: 16 окт 2012
    bq27541-G1, bq27545-G1, bq27541EVM, bq27545EVM Configuring the bq2754x-G1 Data Flash
  • Single Cell Gas Gauge Application Book
    PDF, 9.7 Мб, Файл опубликован: 28 июл 2008
  • Host-Side Gas-Gauge-System Design Considerations for Single-Cell Handheld Apps
    PDF, 152 Кб, Файл опубликован: 12 окт 2007
  • Host System Calibration Method (Rev. B)
    PDF, 140 Кб, Версия: B, Файл опубликован: 19 май 2016
    To add improvements to the Impedance Trackв„ў algorithm, changes have been made to free up firmwarecode space. In the process of freeing up code space, the calibration calculations are no longerautomatically performed by the gauge but must be performed by the host and the results written back tothe gauge. This application note provides a flow on how to implement the calibration algorithm on a
  • MSP430 Microcontroller SW for Handheld Fuel Gauges and Battery Authentication (Rev. A)
    PDF, 350 Кб, Версия: A, Файл опубликован: 26 май 2010
    MSP430, bq26100, bq26100EVM, bq26150, bq26150EVM, bq26500, bq27000, bq27000EVM, bq27200, b MSP430 Microcontroller Software for Handheld Fuel Gauge & Battery Authentication
Серия: BQ27541 (2)
  • Semiconductors > Power Management > Battery Management Products > Battery Fuel Gauge
На английском языке: Datasheet Texas Instruments BQ27541DRZT
