Datasheet ISL6295CVZ - Intersil Даташит ИС, SM, зарядное устройство, L/VOLTAGE FUEL GAUGE — Даташит
Наименование модели: ISL6295CVZ
Купить ISL6295CVZ на РадиоЛоцман.Цены — от 65 до 431 ₽13 предложений от 13 поставщиков Микросхема Чип управления батареи, IC, SM, CHARGER, L/VOLTAGE FUEL GAUGE; Battery Management Function: Fuel Gauge; Battery Type: Li-Ion / Li-Polymer; Vo...... | |||
| ISL6295CVZ Intersil | 72 ₽ | ||
| ISL6295CVZ | по запросу | ||
| ISL6295CVZ (ISL6295CVZ ) Intersil | по запросу | ||
| ISL6295CVZ Renesas | по запросу | ||
Производитель: Intersil
Описание: ИС, SM, зарядное устройство, L/VOLTAGE FUEL GAUGE
ISL6295
Data Sheet November 10, 2005 FN9074.1
Low Voltage Fuel Gauge
The ISL6295 is a cost-effective, highly accurate IC that measures, stores, and reports all of the critical parameters required for rechargeable battery monitoring with a minimum of external components.
It precisely measures charge/ discharge current as well as voltage and temperature of a battery pack. In addition, the ISL6295 accurately accumulates both charge and discharge current as independent parameters. Temperature history can also be maintained for calculating self-discharge effects. The ISL6295 integrates a highly accurate 16-bit (15-bit plus sign) integrating A/D converter that performs calibrated current measurement to within ±0.5% error. On-chip counters precisely track battery charge/discharge and temperature history. Also included are an on-chip voltage regulation circuit, non-crystal time base, and on-chip temperature sensor. The operating voltage range of the ISL6295 is optimized to allow a direct i
- Battery Management Function: Fuel Gauge
- Battery Type: Li-Ion / Li-Polymer
- Диапазон напряжения питания: 2.8 В ... 7 В
- Battery IC Case Style: TSSOP
- Количество выводов: 8
- Рабочий диапазон температрур: -20°C ... +85°C
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: TSSOP
- Семейство: 6295
- Control Interface: Serial, I2C
- Входное напряжение максимальное: 7 В
- Интерфейс: 2 Wire, I2C, Serial
- Number of Series Cells: 1
- Выходное напряжение максимальное: 2.1 В
- Способ монтажа: SMD
- Напряжения питания Vcc: 10 В
Дополнительные аксессуары:
- Electrolube - HTS35SL
- Fischer Elektronik - ICK SMD A 8 SA
- Roth Elektronik - RE933-01
- STANNOL - 631954
