Datasheet LTC2942IDCB-1 - Linear Technology Даташит Батарея FUEL GAUGE LI-ION 5.5 В DFN-6 — Даташит
Linear Technology LTC2942IDCB-1
Наименование модели: LTC2942IDCB-1
Производитель: Linear Technology
Описание: Батарея FUEL GAUGE LI-ION 5.5 В DFN-6
data sheetСкачать Data Sheet
FeaTures
n n n n n n n n n n n n
LTC2942-1 1A Battery Gas Gauge with Internal Sense Resistor and Temperature/Voltage Measurement DescripTion
The LTC®2942-1 measures battery charge state, battery voltage and chip temperature in handheld PC and portable product applications.
Its operating range is perfectly suited for single cell Li-Ion batteries. A precision coulomb counter integrates current through an internal sense resistor between the battery's positive terminal and the load or charger. Battery voltage and on-chip temperature are measured with an internal 14-bit No Latency TM ADC. The three measured quantities (charge, voltage and temperature) are stored in internal registers accessible via the onboard SMBus/I2C interface. The LTC2942-1 features programmable high and low thresholds for all three measured quantities. If a programmed threshold is exceeded, the device communicates an alert using either the SMBus alert protocol or by setting a flag in the internal status register.
L, L
  • Battery Management Function: Fuel Gauge, Status Monitor
  • Battery Type: Lithium Ion
  • Диапазон напряжения питания: 2.7 В ... 5.5 В
  • Интерфейс: I2C, SMBus
  • Battery IC Case Style: DFN
  • Количество выводов: 6
  • Рабочий диапазон температрур: -40°C ... +85°C
  • SVHC: No SVHC (19-Dec-2011)
LTC2942IDCB1, LTC2942IDCB 1
На английском языке: Datasheet LTC2942IDCB-1 - Linear Technology BATTERY FUEL GAUGE LI-ION 5.5 V DFN-6
Политика конфиденциальности
