Datasheet Texas Instruments BQ29419PW — Даташит
СерияBQ29419
МодельBQ29419PW
Защита по напряжению для 2, 3 или 4-элементных литий-ионных аккумуляторов 8-TSSOP от -40 до 110
Voltage Protection for 2-, 3-, or 4-Cell Li-Ion Batteries (2nd Level Protection) datasheet
PDF, 1.0 Мб, Версия: G, Файл опубликован: 18 авг 2008
23 предложений от 19 поставщиков
Микросхема Чип управления батареи, Lithium Ion Protection Voltage Protection for 2, 3, or 4 Cell Li-Ion Batteries Battery Protection Li-Ion 2V...
BQ29419PW
148 ₽
Зенер
Россия и страны ТС
BQ29419PW
от 319 ₽
BQ29419PW
ТаймЧипс
BQ29419PW
Package TypePW
Industry STD TermTSSOP
Package QTY150
Маркировка29419
Width (мм)4.4
Length (мм)3
Thickness (мм)1
Max Height (мм)1.2
  • Stacking Multiple bqq2941x Li-Ion Secondary Voltage Protectors
    PDF, 62 Кб, Файл опубликован: 27 авг 2007
    Li-ion battery applications, requiring five or more series cells, can make use of standard 4-series-cell secondary protectors, such as the bq2941x series. The devices can be stacked as necessary and outputs of individual devices can be combined with optocouplers to produce a single alarm signal if any cell exceeds the threshold. In addition, for undervoltage protection, TLV3011 nanopower comparato
  • Five to Eight-Series-Cell bq20z80 Fuel Gauge
    PDF, 997 Кб, Файл опубликован: 10 сен 2007
    Battery fuel gauging applications requiring five- to eight-series cells may not have an obvious solution. While fully functional solutions are anticipated in the future, currently available chipsets tend to address end-products where four-series cells are the maximum. This report presents an inexpensive solution, using the bq20z80 fuel gauge.
Серия: BQ29419 (3)
  • Semiconductors > Power Management > Battery Management Products > Battery Monitor, Protection & Authentication Solutions
На английском языке: Datasheet Texas Instruments BQ29419PW
