Datasheet ISL9208IRZ - Intersil Даташит OCP/AFE, MULTI-CELL LI-ION, QFN-32 — Даташит
Intersil ISL9208IRZ
Наименование модели: ISL9208IRZ
Микросхема Чип управления батареи, Battery Protection Li-Ion Pack 32Pin QFN EP
ISL9208IRZ
Intersil
75 ₽
ISL9208IRZ
96 ₽
727GS
ISL9208IRZ-T
Intersil
ISL9208IRZ-T
Производитель: Intersil
Описание: OCP/AFE, MULTI-CELL LI-ION, QFN-32
data sheetСкачать Data Sheet
ISL9208
Data Sheet February 16, 2007 FN6446.0
Multi-Cell Li-ion Battery Pack OCP/Analog Front End
The ISL9208 is an overcurrent protection device and analog front end for a microcontroller in a multi-cell Li-ion battery pack.
The ISL9208 supports battery pack configurations consisting of 5 cells to 7 cells in series and 1 or more cells in parallel. The ISL9208 provides integral overcurrent protection circuitry, short circuit protection, an internal 3.3V voltage regulator, internal cell balancing switches, cell voltage monitor level shifters, and drive circuitry for external FET devices for control of pack charge and discharge. Selectable overcurrent and short circuit thresholds reside in internal RAM registers. An external microcontroller sets the thresholds by setting register values through an I2C serial interface. Internal registers also contain the detection delays for overcurrent and short circuit conditions. Using an internal analog multiplexer the ISL9208 provides monitoring
  • Battery Type: Li-Ion
  • Интерфейс: I2C, Serial
  • Battery Protection: Over Current
  • Number of Batteries: 7
  • Диапазон напряжения питания: 9.2 В ... 30.1 В
  • Battery IC Case Style: QFN
  • Количество выводов: 32
  • Рабочий диапазон температрур: -40°C ... +85°C
  • SVHC: No SVHC (20-Jun-2011)
  • Семейство: 9208
  • Battery Management Function: Protector
  • Control Interface: Serial, I2C
  • Входное напряжение максимальное: 30.1 В
  • Number of Series Cells: 7
  • Тип корпуса: QFN
  • Способ монтажа: SMD
  • Напряжения питания Vcc: 36 В
На английском языке: Datasheet ISL9208IRZ - Intersil OCP/AFE, MULTI-CELL LI-ION, QFN-32
