Datasheet ISL9209IRZ - Intersil Даташит ИС, CHARGING SYSTEM безопасность, 12DFN — Даташит
Наименование модели: ISL9209IRZ
14 предложений от 14 поставщиков
ISL9209IRZ
Intersil
65 ₽
ISL9209IRZ
LifeElectronics
ISL9209IRZ
Intersil
Контест
ISL9209IRZ
Intersil
Производитель: Intersil
Описание: ИС, CHARGING SYSTEM безопасность, 12DFN
data sheetСкачать Data Sheet
ISL9209
Data Sheet April 25, 2006 FN6274.0
Charging System Safety Circuit
The ISL9209 is an integrated circuit (IC) optimized to provide a redundant safety protection to a Li-ion battery from failures of a charging system.
The IC monitors the input voltage, the battery voltage, and the charge current. When any of the three parameters exceeds its limit, the IC turns off an internal P-channel MOSFET to remove the power from the charging system. In addition to the above protected parameters, the IC also monitors its own internal temperature and turns off the P-channel MOSFET when the temperature exceeds 140°C. Together with the battery charger IC and the protection module in a battery pack, the charging system using the ISL9209 has triple-level protection and is two-fault tolerant. The IC is designed to turn on the internal PFET slowly to avoid inrush current at power up but will turn off the PFET quickly when the input is overvoltage in order to remove the power before any damage occ
  • Battery Type: Li-Ion
  • Number of Batteries: 1
  • Диапазон напряжения питания: 4.3 В ... 5.5 В
  • Battery IC Case Style: TDFN
  • Количество выводов: 12
  • Рабочий диапазон температрур: -40°C ... +85°C
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: TDFN
  • Семейство: 9209
  • Battery Management Function: Protector
  • Battery Protection: Over Current, Over Voltage
  • Входное напряжение максимальное: 5.5 В
  • Способ монтажа: SMD
На английском языке: Datasheet ISL9209IRZ - Intersil IC, CHARGING SYSTEM SAFETY, 12DFN
