Datasheet LTC1998CS6 - Linear Technology Даташит В детектор, LI ион, BATTERYSOT23-6 — Даташит
Linear Technology LTC1998CS6
Наименование модели: LTC1998CS6
38 предложений от 24 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Управление батареями
LTC1998CS6#TRPBF
87 ₽
LTC1998CS6#TRPBF
104 ₽
SUV System
LTC1998CS6#TRMPBF
727GS
LTC1998CS6
Производитель: Linear Technology
Описание: В детектор, LI ион, BATTERYSOT23-6
data sheetСкачать Data Sheet
FEATURES
n n n n n n n
LTC1998 2.5µA, 1% Accurate SOT-23 Comparator and Voltage Reference for Battery Monitoring DESCRIPTION
The LTC®1998 is a micropower comparator and a precision adjustable reference in a 6-pin SOT-23 package that is optimized for lithium-ion low battery detection circuits.
The LTC1998 features a voltage detection circuit with an adjustable threshold voltage and hysteresis. The threshold voltage can be programmed from 2.5V to 3.25V with two external resistors. A 10mV to 750mV hysteresis can be added with a third external resistor. A proprietary internal architecture maintains 1% threshold voltage accuracy over temperature with low cost 1% external resistors. A separate power supply pin, VLOGIC, allows the battery-low logic output to operate below the battery voltage, allowing compatibility with low voltage microprocessors without a pull-up resistor. Power supply glitches are eliminated by preventing the cross-conducting current which occurs when the output changes s
  • Battery Type: Li-Ion
  • Диапазон напряжения питания: 1.5 В ... 5.5 В
  • Battery IC Case Style: SOT-23
  • Количество выводов: 6
  • Рабочий диапазон температрур: -40°C ... +85°C
  • SVHC: No SVHC (19-Dec-2011)
  • Семейство: 1998
  • Number of Series Cells: 1
  • Тип корпуса: SOT-23
  • Способ монтажа: SMD
На английском языке: Datasheet LTC1998CS6 - Linear Technology V DETECTOR, LI ION, BATTERYSOT23-6
