Datasheet NCP361SNT1G - ON Semiconductor Даташит ИС, батарея PROTECTOR, TSOP-5 — Даташит
Наименование модели: NCP361SNT1G
59 предложений от 24 поставщиков
Чип контроля напряжения, Overvoltage Protection Circuit, USB Positive, with Internal PMOS FET and Overcurrent Protection OVLO 5.675V, OCP 750mA, TSOP-5, 3000-REEL...
Microfind
NCP361SNT1G
от 39 ₽
NCP361SNT1G
от 70 ₽
Зенер
Россия и страны ТС
NCP361SNT1G
от 83 ₽
NCP361SNT1G
Производитель: ON Semiconductor
Описание: ИС, батарея PROTECTOR, TSOP-5
data sheetСкачать Data Sheet
NCP361 USB Positive Overvoltage Protection Controller with Internal PMOS FET and Overcurrent Protection
The NCP361 disconnects systems at its output when wrong VBUS operating conditions are detected at its input.
The system is positive over-voltage protected up to +20 V. Thanks to an integrated PMOS FET, no external device is necessary, reducing the system cost and the PCB area of the application board. The NCP361 is able to instantaneously disconnect the output from the input if the input voltage exceeds the overvoltage threshold (5.675 V). Thanks to an overcurrent protection, the integrated PMOS is turning off when the charge current exceeds current limit (see options in ordering information). The NCP361 provides a negative going flag (FLAG) output, which alerts the system that voltage, current or overtemperature faults have occurred. In addition, the device has ESD-protected input (15 kV Air) when bypassed with a 1 mF or larger capacitor.
Features http://onsemi.com MARKING DIAGRAMS
  • Battery Protection: Over Current, Over Voltage
  • Диапазон напряжения питания: 1.2 В ... 20 В
  • Battery IC Case Style: TSOP
  • Количество выводов: 5
  • Рабочий диапазон температрур: -40°C ... +85°C
На английском языке: Datasheet NCP361SNT1G - ON Semiconductor IC, BATTERY PROTECTOR, TSOP-5
