Datasheet MAX11080GUU/V+ - Maxim Даташит ИС, LI/BATTERY MANAGEMENT, 38TSSOP — Даташит
Наименование модели: MAX11080GUU/V+
13 предложений от 13 поставщиков Микросхема Чип управления батареи, Battery Monitoring Li-Ion 3.3V Automotive 38Pin TSSOP | |||
| MAX11080GUU/V+T Maxim | по запросу | ||
| MAX11080GUU/V+T Analog Devices | по запросу | ||
| MAX11080GUU/V+TG0J Maxim | по запросу | ||
Производитель: Maxim
Описание: ИС, LI/BATTERY MANAGEMENT, 38TSSOP
19-4584; Rev 0; 5/09
12-Channel, High-Voltage Battery-Pack Fault Monitor
General Description
The MAX11080 is a battery-pack fault-monitor IC capable of monitoring up to 12 lithium-ion (Li+) battery cells.
This device is designed to provide an overvoltage or undervoltage fault indication when any of the cells cross the user-selectable threshold for longer than the set program-delay interval. The overvoltage levels are pin selectable from +3.3V to +4.8V in 100mV increments, and have a guaranteed accuracy of ±25mV over the entire temperature range. The undervoltage level is also user selectable from +1.6V to +2.8V in 200mV increments. These levels are guaranteed to ±100mV over the entire temperature range. Undervoltage detection can be disabled as one of the user-configuration options. The MAX11080 has a built-in level-shifter that allows up to 31 MAX11080 devices to be connected in a daisychain fashion to reduce the number of interface signals needed for large stacks of series batteries
- Battery Type: Lithium
- Number of Batteries: 12
- Диапазон напряжения питания: 6 В ... 72 В
- Battery IC Case Style: TSSOP
- Количество выводов: 38
- Рабочий диапазон температрур: -40°C ... +105°C
- SVHC: No SVHC (18-Jun-2010)
