Datasheet LTC1479CG - Linear Technology Даташит ИС, BATT зарядное устройство, SMD, SSOP36, 1479 — Даташит
Linear Technology LTC1479CG
Наименование модели: LTC1479CG
32 предложений от 19 поставщиков
Микросхема Чип управления батареи, PowerPath Controller for Dual Battery Systems 6V to 28V 36Pin SSOP Tube
LTC1479CG#PBF
356 ₽
Зенер
Россия и страны ТС
LTC1479CG
от 902 ₽
Эиком
LTC1479CG#PBF
от 2 484 ₽
TradeElectronics
LTC1479CG#TR
Производитель: Linear Technology
Описание: ИС, BATT зарядное устройство, SMD, SSOP36, 1479
data sheetСкачать Data Sheet
LTC1479 PowerPath Controller for Dual Battery Systems
FEATURES
s s
DESCRIPTION
The LTC ®1479 is the "heart" of a total power management solution for single and dual battery notebook computers and other portable equipment.
The LTC1479 directs power from up to two battery packs and a DC power source to the input of the main system switching regulator. It works in concert with related LTC power management products (e.g. LTC1435, LT ®1511, etc.) to create a total system solution; starting from the batteries and the DC power source, and ending at the input of each of the computer's complex loads. A system-provided power management µP monitors and actively directs the LTC1479. The LTC1479 uses low loss N-channel MOSFET switches to direct power from three main sources. An adaptive current limiting scheme reduces capacitor and battery inrush current by controlling the gates of the MOSFET switches during transitions. The LTC1479 interfaces directly to the LT1510, LT1511 and LT1620/LTC1435 batt
  • Battery Type: Li-Ion / NiCd / NiMH / Lead-Acid
  • Number of Batteries: 2
  • Диапазон напряжения питания: 6 В ... 28 В
  • Battery IC Case Style: SSOP
  • Количество выводов: 36
  • Рабочий диапазон температрур: 0°C ... +70°C
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: SSOP
  • Семейство: 1479
  • Control Interface: Serial
  • Выходной ток максимальный: 0.001 А
  • Выходное напряжение максимальное: 42 В
  • Способ монтажа: SMD
  • Device Type: Power
  • Количество выходов: 6
  • Выходное напряжение: 42 В
Дополнительные аксессуары:
  • Electrolube - HTS35SL
  • Fischer Elektronik - ICK SMD A 8 SA
  • Roth Elektronik - RE931-06
  • STANNOL - 574601
На английском языке: Datasheet LTC1479CG - Linear Technology IC, BATT CHARGER, SMD, SSOP36, 1479
