Datasheet MCCM35010-RH - Multicomp Даташит Мостовой выпрямитель, 1PH, 35 А, 1 кВ, QC — Даташит
Наименование модели: MCCM35010-RH
Купить MCCM35010-RH на РадиоЛоцман.Цены — от 117 до 175 ₽Мостиковый выпрямитель, MULTICOMP MCCM35010-RH Bridge Rectifier Diode, Single, 1kV, 35A, Module, 1.2V, 4Pins | |||
| MCCM35010-RH Multicomp | 117 ₽ | ||
| MCCM35010-RH Multicomp | 175 ₽ | ||
Производитель: Multicomp
Описание: Мостовой выпрямитель, 1PH, 35 А, 1 кВ, QC
FEATURES & MECHANICAL DATA: - Case: Metal, electrically isolated metal case for maximum heat dissipation - Terminals: Plated 0.25 Inches Quick Disconnect - Surge overload rating to 400 Amperes - Weight: 1 ounce, 30 grams - Mounting Position: Any
Maximum Ratings and Electrical Characteristics Rating @ 25°C ambient temperature unless otherwise specified.
Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20 % MULTICOMP TYPE NO. CHARACTERISTICS MCCM2502 MCCM2506 MCCM25010 MCCM2500 MCCM2501 MCCM2504 MCCM2508 MCCM3502 MCCM3506 MCCM35010 MCCM5000 MCCM3501 MCCM3504 MCCM3508 MCCM5002 MCCM5006 MCCM50010 50 35 50 100 70 100 200 140 200 400 280 400 600 420 600 I2t Rating for fusing (t < 8.3ms) (A2S) 800 560 800 1000 800 1000
Max. Recurrent Peak Reverse Voltage (V) Max. RMS Input Voltage (V) Max. DC Blocking Voltage (V)
Max. Average Non-repetitive Forward Current Multicomp Type Peak Forward For No. Surge Current Resistive Load @ Rated Laod @ TC=55
- Number of Phases: Single
- Repetitive Reverse Voltage Max, Vrrm: 1000 В
- Forward Current, If(AV): 35 А
- Forward Voltage Max, VF: 1.2 В
- Способ монтажа: Quick Connect
RoHS: Y-Ex
Дополнительные аксессуары:
- NTE Electronics - NTE5344
- Vishay - GBPC3510A
MCCM35010RH, MCCM35010 RH
