Datasheet XRT5683AID-F - Exar Даташит ИС, PCM, INTERFACE, 18SOIC — Даташит
Exar XRT5683AID-F
Наименование модели: XRT5683AID-F
Чип интерфейса, PCM Transceiver, 1-Func, Bipolar, PDSO18, 0.3INCH, GREEN, PLASTIC, SO-18
XRT5683AID-F
Exar
64 ₽
XRT5683AID-F
Exar
754 ₽
XRT5683AID-F
Exar
980 ₽
XRT5683AID-F
Производитель: Exar
Описание: ИС, PCM, INTERFACE, 18SOIC
data sheetСкачать Data Sheet
XR-T5683A
...the analog plus company TM
PCM Line Interface Chip
June 1997-3
FEATURES D Single 5V Supply D Receiver Input Can Be Either Balanced or Unbalanced D Up To 8.448Mbps Operation In Both Tx and Rx Directions
Каталог производителяКаталог производителя
Your Electronic Engineering Resource
XRT5683A PCM Line Interface Chip
General Description:
The XR-T5683A is a PCM line interface chip consisting of both transmit and receive circuitry.
This device is offered in a plastic dual in-line (PDIP) or in a surface mount package (SOIC). The maximum bit rate of the chip is 8.448Mbps, and the signal level to the receiver can be attenuated by -10dB cable loss at one-half the bit rate. At nominal supply voltage operation, the typical current consumption is 40mA.
Key Features:
Дополнительные аксессуары:
  • WUERTH ELEKTRONIK - 749020013
XRT5683AIDF, XRT5683AID F
На английском языке: Datasheet XRT5683AID-F - Exar IC, PCM, INTERFACE, 18SOIC
