Datasheet XRT6166CD-F - Exar Даташит ИС, PROCESSOR, цифровой DATA, 28SOIC — Даташит
Exar XRT6166CD-F
Наименование модели: XRT6166CD-F
Цифровой сигнальный процессор DSP, EXAR XRT6166CD-F, 8Bit Digital Signal Processor 2.048MHz 28Pin SOIC
XRT6166CD-F
Exar
1 421 ₽
XRT6166CD-F
Exar
1 421 ₽
XRT6166CD-F
Exar
15 168 ₽
XRT6166CD-F
Exar
Производитель: Exar
Описание: ИС, PROCESSOR, цифровой DATA, 28SOIC
Каталог производителяКаталог производителя
Your Electronic Engineering Resource
XRT6166 Co Directional Digital Data Processor
General Description:
The XR-T6166 is a CMOS device which contains the digital circuitry necessary to interface both directions of a 64kbps data stream to 2.048Mbps transmit and receive PCM time-slots.
The XR-T6166 and the companion XR-T6164 line interface chip together form a CCITT G.703 compliant 64kbps co directional interface. The XR-T6166 contains separate transmit and receive sections. The transmitter transforms 8 bit serial data from a 2.048Mbps time-slot into an encoded 64kbps data stream. The receiver, which performs the reverse operation, decodes the 64kbps data, extracts a clock signal, and then outputs the data to a 2.048Mbps time-slot. The XR-T6166 provides features which allow the repetitions and deletions of both received and transmitted data as clock skews and transients occur. These slip occurrences are indicated by byte insertion and deletion flags. Outputs are also provided for ext
Дополнительные аксессуары:
  • Exar - XRT6164CD-F
XRT6166CDF, XRT6166CD F
На английском языке: Datasheet XRT6166CD-F - Exar IC, PROCESSOR, DIGITAL DATA, 28SOIC
