Datasheet 74LVXC3245QSC - Fairchild Даташит ИС, 8 бит VOLT INTERFACE TXRX, QSOP-24 — Даташит
Наименование модели: 74LVXC3245QSC
Купить 74LVXC3245QSC на РадиоЛоцман.Цены — от 23 до 191 ₽15 предложений от 15 поставщиков IC TRNSLTR BIDIRECTIONAL 24QSOP. Voltage Level Translator Bidirectional 1 Circuit 8 Channel 24-QSOP. Logic - Translators, Level Shifters | |||
| 74LVXC3245QSC Rochester Electronics | 66 ₽ | ||
| 74LVXC3245QSC ON Semiconductor | 68 ₽ | ||
| 74LVXC3245QSC ON Semiconductor | 191 ₽ | ||
| 74LVXC3245QSC Fairchild | по запросу | ||
Производитель: Fairchild
Описание: ИС, 8 бит VOLT INTERFACE TXRX, QSOP-24
74LVXC3245 -- 8-Bit Dual Supply Configurable Voltage Interface Transceiver with 3-STATE Outputs
February 2009
74LVXC3245 8-Bit Dual Supply Configurable Voltage Interface Transceiver with 3-STATE Outputs
Features
Bidirectional interface between 3V and 3V-to-5V buses Control inputs compatible with TTL level Outputs source/sink up to 24 mA Guaranteed simultaneous switching noise level and dynamic threshold performance Implements patented EMI reduction circuitry Flexible VCCB operating range Allows B Port and VCCB to float simultaneously when OE is HIGH Functionally compatible with the 74 series 245
- Выходной ток: 24 мА
- Logic Type: Voltage Interface Transceiver
- Количество каналов: 8
- Input Level: 3.85 В
- Logic Case Style: QSOP
- Количество выводов: 24
- Диапазон напряжения питания: 2.7 В ...
3.6 В
