Помощь в переводе проектов на ПЛИС азиатских брендов
Datasheet HI5812JIPZ - Intersil Даташит ИС, ADC, 12 бит, 50 kSPS, DIP-24 — Даташит
Intersil HI5812JIPZ
Наименование модели: HI5812JIPZ
13 предложений от 10 поставщиков
CMOS 20 Microsecond, 12-Bit, Sampling A/D Converter with Internal Track and Hold | IC ADC 12BIT SAR 24DIP
HI5812JIPZ
Intersil
63 ₽
HI5812JIPZ
Intersil
HI5812JIPZ
Renesas
HI5812JIPZ
Renesas
Производитель: Intersil
Описание: ИС, ADC, 12 бит, 50 kSPS, DIP-24
data sheetСкачать Data Sheet
HI5812
Data Sheet March 31, 2005 FN3214.6
The HI5812 is a fast, low power, 12-bit, successive approximation analog-to-digital converter.
It can operate from a single 3V to 6V supply and typically draws just 1.9mA when operating at 5V. The HI5812 features a built-in track and hold. The conversion time is as low as 20µs with a 5V supply. The twelve data outputs feature full high speed CMOS three-state bus driver capability, and are latched and held through a full conversion cycle. The output is user selectable, i.e., 12-bit, 8-bit (MSBs), and/or 4-bit (LSBs). A data ready flag, and conversion-start input complete the digital interface. An internal clock is provided and is available as an output. The clock may also be over-driven by an external source.
  • Разрешение: 12
  • Частота выборки: 50 kSPS
  • Input Channel Type: Single Ended
  • Data Interface: Parallel
  • Supply Voltage Range-Analog: 3 В ... 6 В
  • Ток потребления: 1.9 мА
  • Тип корпуса: DIP
  • Количество выводов: 24
На английском языке: Datasheet HI5812JIPZ - Intersil IC, ADC, 12 bit, 50 kSPS, DIP-24
