Datasheet MPVZ5010GW7U - Freescale Даташит ИС, PRESSURE SENSOR, 0 TO 10KPA, 8-DIP — Даташит
Наименование модели: MPVZ5010GW7U
Производитель: Freescale
Описание: ИС, PRESSURE SENSOR, 0 TO 10KPA, 8-DIP
Freescale Semiconductor Technical Data
MPVZ5010G Rev 0, 09/2005
Integrated Silicon Pressure Sensor On-Chip Signal Conditioned, Temperature Compensated and Calibrated
The MPVZ5010G series piezoresistive transducers are state-of-the-art monolithic silicon pressure sensors designed for the appliance, consumer, healthcare, industrial and automotive market.
The analog output can be read directly into the A/D input of Freescale microcontrollers. This transducer combines advanced micromachining techniques, thin-film metallization, and bipolar processing to provide an accurate, high level analog output signal that is proportional to the applied pressure. The axial port has been modified to accommodate industrial grade tubing. Features · · · · 5.0% Maximum Error over 0° to 85°C Temperature Compensated over -40° to +125°C Durable Thermoplastic (PPS) Package Available in Surface Mount (SMT) or Through-hole (DIP) Configurations
MPVZ5010G SERIES
- Pressure Type: Gauge
- Operating Pressure Range: 0 ... 10kPa
- Connection Size: 5.588 мм
- Ток потребления: 5 мА
- Тип корпуса: DIP
- Количество выводов: 8
- Диапазон напряжения питания: 4.75 В ... 5.25 В
