Datasheet SSM2380CBZ-REEL7 - Analog Devices Даташит ИС, аудио усилитель, D, 4 Вт, WLCSP-16 — Даташит
Наименование модели: SSM2380CBZ-REEL7
|  Купить SSM2380CBZ-REEL7 на РадиоЛоцман.Цены — от 44 до 356 ₽ 35 предложений от 15 поставщиков Микросхема Усилитель звуковой частоты, ANALOG DEVICES SSM2380CBZ-REEL7 Audio Power Amplifier, D, 2Channel, 4W, 2.5V to 5.5V, LCSP, 16Pins | |||
| SSM2380CBZ-REEL7 Analog Devices | 77 ₽ | ||
| SSM2380CBZ-REEL7 Analog Devices | 109 ₽ | ||
| SSM2380CBZ-REEL7 Analog Devices | от 127 ₽ | ||
| SSM2380CBZ-REEL7 Analog Devices | 265 ₽ | ||
Производитель: Analog Devices
Описание: ИС, аудио усилитель, D, 4 Вт, WLCSP-16
2 Ч 2 W, Filterless, Stereo, Class-D Audio Amplifier with ALC and I2C SSM2380
FEATURES
Filterless, stereo, Class-D amplifier with - modulation 2 W into 4  load and 1.4 W into 8  load at 5.0 V supply with <1% total harmonic distortion plus noise (THD + N) Highly configurable I2C interface for gain adjust, automatic level control (ALC), and ultralow EMI emissions mode MODE pin can disable I2C interface for more traditional stereo amplifier configuration Stereo-to-mono mixer option via I2C control 93% efficiency at 5.0 V, 1.4 W into 8  speaker Signal-to-noise ratio (SNR): >100 dB Single-supply operation from 2.5 V to 5.5 V Ultralow shutdown current: 20 nA Short-circuit and thermal protection Pop-and-click suppression Available in 16-ball, 2.0 mm Ч 2.0 mm WLCSP
The SSM2380 features a high efficiency, low noise modulation scheme that requires no external LC output filters.
The modulation continues to provide high efficiency even at low output power. The SSM2380 operates with 93% efficiency
- Класс усилителя: D
- Количество каналов: 2
- Выходная мощность: 4 Вт
- Диапазон напряжения питания: 2.5 В ... 5.5 В
- Load Impedance: 4 Ом
- Рабочий диапазон температрур: -40°C ... +85°C
- Тип корпуса: LCSP
- Количество выводов: 16
SSM2380CBZREEL7, SSM2380CBZ REEL7
 Скачать Data Sheet
Скачать Data Sheet
